A list for those not inclined to look for one
(edited from:
http://npora.ipbhost.com//index.php?showtopic=9577Non Technical:
AFAICT = As Far As I Can Tell
AFAIK = As Far As I Know
BFH = Big Freakin Hammer
BS = Back Space (or Bull $hit)
BTW = By The Way
FSM = Flying Spaghetti Monster
FTW = For The Win
FUBARed = F'ed Up Beyond All Repair
FYI= for your information
IBMS= I bruised my spleen
IIRC = If I Remember Correctly
IMHO=In My Humble Opinion
IMO = In My Opinion
KISS = Keep It Simple Stupid
LOL = Laughing Out Loud
LMAO = Laughing My Ass Off
MSIB2 = My Spleen Is Bruised As Well
NSFW = Not Safe For Work
NWS = Not Work Safe
PM = Private or Personal Message
POS = Piece of $hit
ROFL = Rolling On Floor Laughing
ROFLMAO = Rolling On Floor Laughing My Ass Off
SOL = $hit Outta Luck
WFO = Wide F'ing Open
WTB= Wanting To Buy
WTF = What The F$$k
WOT = Wide Open Throttle (maybe technical vs non)
W/ = With
W/O = with out
Technical:ABS = AntiLock Brake System
A/C or AC = Air Conditioning
ASE = Automotive Service Excellence
AT = Automatic Transmission
ATF = Automatic Tranny Fluid
BDC = Bottom Dead Center
BJ = Ball Joint
BTDC = Before Top Dead Center
CFM = Cubic Feet Per Minute
CL = Center Link
CV = Constant Velocity
DS = Drive Shaft
ECU = Engine Control Unit
EFI = Electronic Fuel Injection
EGR = Exhaust Gas Recirculation
FSM = Factory Service Manual
HP = High Pinion or Horse Power
IA = Idler Arm
IAB = Idler Arm Brace
IAC = Idle Air Control Valve
IB4TL = In Before The Lockdown
IFS = Independent Front suspension
IRS = Independent Rear Suspension (or Internal Revenue Service)
JGC = Jeep Grand Cherokee
KPR = Kilometers Per Hours
LCA = Lower Control Arm
LSD = Limited Slip Diff
LP = Low Pinion
MAF = Mass Airflow Sensor
MAP = Manifold Air Pressure
MPFI = Multi Port Fuel Injection
MPG= Miles Per Gallon
MPH = Miles Per Hour
MTF = Manual Tranny Fluid
MT = Manual Transmission
O2 = Oxygen
PA = Pitman Arm
PB: P'Blaster
PS = Power Steering (could mean Post Script)
RP = Ring and Pinion
RPM = Revolutions Per Minute
SAE = Society of Automotive Engineers
SAS = Solid Axle Suspension
SYE = Slip Yoke Eliminator
TBI = Throttle Body Injection
TB = Throttle Body
T-Belt = Timing Belt
TBar = Torsion Bar
TDC = Top Dead Center
TPI = Throttle Port Injection (or tuned port injection)
TRE = Tie Rod End
T-Stat = ThermoStat
TT = Twin Turbo
TCase = Transfer Case
TPI= Threads per inch
TPS= Throttle position sensor
UCA = Upper Control Arms
VVT = Variable Valve Timing
SC = Super Charger ( R ) R also means oversized turbo when used next to T or TT
SOHC = Single OverHead Cam
DOHC = Dual OverHead Cam
