^ No one really knows what kind of equipment RAT uses, so a peer review is out of the question. Based on his own description it however makes sense to me, as what he tests is strength of oil film in PSI before metal to metal contact occurs, which obviously what you don't want to happen in an engine of any design and what IMHO can define oil's engine protection capabilities. Like I said above, his "prolong" additive plugs are suspicious of vested interest but the oil ranking rings true.
P.S. He has done some digging into oil filters (chapter 49 at the end of the blog) and the results are interesting. Honda, Hyundai and Toyota branded filters did poorly in his quality assessments. Search for "49" or "motorcraft" to get to the test.
...which is exactly the problem. If he doesn't reveal his equipment or procedures, you cannot replicate his results and no one can check it. It doesn't matter why he can't reveal it(he claims it's proprietary, but who knows), as it stands now, his results are at best, questionable because no one can check them.
And let me ask you this question: if he has a miracle rig that can produce results accurate to 5 to 6 significant figures(again, that's a pretty big deal) when even well-established tests like the 4-ball test have poor repeatability, he would have been a very, very rich man now. Oil companies would have been all over him, but that's not the case as far as we know, which implies one of two things, neither of which is good.
- the results aren't really meaningful enough for any oil companies to pay any mind to a miracle rig like this.
- his rig can't produce the results any better than most of the equipment oil companies currently have access to.
The thing that really makes me really question him is his attitude. Most of his responses to his criticizers don't sound like something coming out of an engineer.
I will have a look at the oil filter testing assuming he shares the testing procedures.
To counter his viscosity point, a lot of cars run on XW-20 just fine so even his "run anything above XW-30 if you care" is questionable. There was also a fairly new Accord on the Accord forum that had an engine failure after using 0W-40 instead of the recommended 0W-20. Whether or not that's related to the oil, hard to say for sure, but to me that's more than a coincidence.
Just my hunch, but I trust the engineers at Toyota way more than him.
Edit: the oil filter test seems to be him cutting them open and taking a look at the construction. It's alright and a lot of people do that.
