Another small update on this one. I've been driving it a couple hundred kms a week and have really been enjoying it. The idle was always a little rough, but it never stalled out so I didn't worry about it much. Then one night it finally stalled out at a light, and then stalled a few more times the next day. I went through it and did a quick tune up (air filter, fuel filter, spark plugs, PCV) and checked all the vacuum lines for leaks. I also tweaked the mixture and idle setting on the carb just a bit. That seemed to smooth things out pretty good.
It gets really hot inside the damn thing with the glass T-tops above you, so for shits and giggles I decided to play around with the AC. Had a buddy pull a vacuum on the system and then I re-filled it with some RedTek and a Stop Leak. I did a half arsed leak check at all the accessible joint with some soapy water and everything seemed tight. System has been blowing ice cold for about a month now, so that's pretty sweet
Gotta love a 30 year old car with working AC.
I gave it a wash and a coat of Mequires Tech Wax on the weekend, and she's looking alright for a beater. This was Monday morning at work:
I also scored a new set of grey seat belts, a good dash pad and some spare center caps out of a local car someone was parting out. Still need to clean those bits up and install them.
