I think I am ready to detail my car in thee spring..... but first of all, after a really detail carwash, I found lot of brown spot on my white colour paint. I presume those are caused by brake dust. I used to use scratch remover to remove them. If I am going to clay the car, should I bother with scratch remover?
What you are seeing is rail dust.....which are tiny metal particles that have embedded into your paint. Basically, it's caused by the friction between the rails and the train wheels. These particles during transit bond to your clear coat and will rust in a very short time.......hence the many rust coloured spots that you are seeing.
To remove them, you'll need to use clay bar and a lubricant. Any other questions just let me know.
Hi, my car is not new. It is going to be 4 years old this summer. I think they are brake dust; the rust spots are more this year. I believe this is due the aftermarket/performance brake pad installed last year.
Your car doesn't need to be new to have rail dust bonded to your paint. If it was never properly removed, it will still be there. But regardless if it's rail dust or brake dust, it will need to be removed with clay bar.
Very true.
I am a cheap perfectionist; I want good result but I get no money. I do not plan to purchase any power equipment, so I don't mind to use elbow grease. I read the 20+ pages of posting. I am still a bit confuse about sealer. I do not plan to shop at eshine; so my product purchasing selection pretty much limited to the big blocks store in GTA. I am not too sure about the order of using wax, polish, sealer, etc.
So, please correct my planning for detailing my car's exterior:
- I have heard to stripe the old wax, I can use dish washing liquid to wash my car.
- Dry it under shades; but previous experience tells me it may be good to dry it under the sun and then park the car in the shade immediate after. It helps to dry out moisture trapped behind some trimmings.
- Touch up any paint chip
- Claying: I have a Meguiar clay kit. Should I start from 'dirty' portion (front) or 'cleaner' part (roof)?
- Waxing: I have some kind of Meguiar Gold Class™ Carnauba wax. i know I have to work in small area. Should I practice straight line application, not circular?
- Remove wax by using Microfider cloth; remove any tag on it. Straight line action too?
- When should I apply the sealer? According to previous discussion, I think it comes to conclusion that sealer work good on light colour car?
- Is there sealer available in the big block store that I should trust?
Thanks for all your help!
Yes, you can use dish soap to strip any wax or sealant that you have applied.
Dry your car immediately and don't let the sun dry it for you. Assuming that you aren't using a de-ionized water filtration system, minerals in your water will cause harsh water spots on your paint.
For claying, it doesn't really matter what panel you start with first. The key is to always use clean clay. Once the clay gets dirty fold it over to you get a clean spot......and when you can't any longer discard it. And if you ever drop a piece be sure to just toss it.
As for applying waxes and sealants I always recommend applying it in a straight line versus circular motions. If you plan on applying a wax
AND a sealant make sure that you apply the sealant first and not the wax. Waxes will bond to sealants, but not the other way around. I don't purchase my products from local stores, but I'm guessing that if you were to find a sealant in a store like Canadian Tire, it would be from Meguiars.....which is fine.
Any other questions, just let me know.
