Has anyone drove at night in near freezing conditions while it is snowing? Pretty specific conditions but I did last night and it appears LED lights are near useless. They don't generate enough heat so the ice/snow mix just builds and freezes over the lenses. Ye olde halogen Ridgeline lights were fine. Plenty of drivers on pullouts and at the service stations trying to clear their lights. What manufacturer will offer electrically heated headlights first? An extra "cold weather" package.
Mercedes use to have heated washer fluid tanks. They had a heater coil that circulated engine coolant into the washer fluid reservoir. It was a pretty good systems to keep headlamp lenses and the windshield clear in cold conditions.
The MDX has LEDs, haven't had any issues. It does have washers that spray well but not sure they'd clear ice. I may not have hit the right conditions. Heavy fog in freezing conditions can really ice them over, as well as freezing rain. Mix in a little road grime and then the lights can get dim.
Quote from: bridgecity on December 07, 2023, 01:17:49 pmThe MDX has LEDs, haven't had any issues. It does have washers that spray well but not sure they'd clear ice. I may not have hit the right conditions. Heavy fog in freezing conditions can really ice them over, as well as freezing rain. Mix in a little road grime and then the lights can get dim. Yeah it's pretty specific conditions that we don't often get. Cold enough to ice over on the car but warm enough to melt off the road. Usually if it's snowing here it is colder here. Bothe Volvos and the LR4 use heated washer nozzles. Not sure how much that helps.
The GX has headlight sprayers, but when its actual built up ice, fughetabouit, ze squirters, zey do nothing!!!
Quote from: Fobroader on December 07, 2023, 01:36:06 pmThe GX has headlight sprayers, but when its actual built up ice, fughetabouit, ze squirters, zey do nothing!!!GX has led headlights?
Quote from: ktm525 on December 07, 2023, 01:44:51 pmQuote from: Fobroader on December 07, 2023, 01:36:06 pmThe GX has headlight sprayers, but when its actual built up ice, fughetabouit, ze squirters, zey do nothing!!!GX has led headlights?Some sort of triple LED projectors
