Author Topic: Quick Spin: 2012 Honda Pilot Touring  (Read 3228 times)
Offline Autos_Editor
  • Carma: +91/-560
« on: May 03, 2012, 04:03:42 am »
Honda Pilot is a utilitarian vehicle that gets its job done efficiently, but without anything to set itself above competitors.
Read More...
Offline nlm
  • Carma: +58/-82
Re: Quick Spin: 2012 Honda Pilot Touring
« Reply #1 on: May 03, 2012, 08:32:41 am »
Quality is behind the Dodge Durango!?!
Offline redman
  • Carma: +100/-298
« Reply #2 on: May 03, 2012, 10:03:53 am »
This product clearly was made for the U.S. market as I barely see them here in the G.T.A.. You can practically place a Ford/Gm badge on this thing as it lacks the distinction of the Honda brand (maybe that was the intent). Either way the design looks long in the tooth considering others have managed to squeeze out more style out their big blocks on wheels.
Offline bridgecity
  • Carma: +126/-182
  • Cars: 2014 MDX; 2007 Tundra
« Reply #3 on: May 03, 2012, 10:18:19 am »
I found this odd:
"Cruising at 100 km/h, the engine turns at 2,000 rpm, and 120 shows 2,500 on the tach. "
My '03 shows a tick over 2000rpm at 120.  Maybe the newer ones rev higher so that 3 cylinders can pull it along at higher speeds?
nsmyhte
« Reply #4 on: May 03, 2012, 02:33:55 pm »
Its a good, solid SUV.  Its just getting a little dated but I'm sure the replacement is just around the corner.
Offline jyarkony
  • Carma: +119/-153
    • Autos.ca
  • Cars: 2003 VW Jetta Wagon 1.8T; 2001 VW GTI VR6
« Reply #5 on: May 03, 2012, 09:21:00 pm »
I found this odd:
I know... I thought that seemed a bit high for its cruising speed, so had to check several times. And I believe it was pretty consistent whether in 3- or 6-cylinder mode, although I didn't specifically document whether there were different engine speeds in different engine modes... now I'm curious. But not curious enough to drive this truck again anytime soon. I will check with Honda reps to find out if that is feasible.
Do I contradict myself?
Very well then I contradict myself,
(I am large, I contain multitudes.)
                                                        –Walt Whitman
Offline bombastic
  • Carma: +14/-261
  • Cars: Mazda 626, Mazda MPV, Toyota Camry, VW Tiguan, VW Passat, Dodge GC
« Reply #6 on: May 03, 2012, 09:46:08 pm »
50k$ for this car? Forget it...Honda is delusional for sure.
Bombastic
Offline bridgecity
  • Carma: +126/-182
« Reply #7 on: May 04, 2012, 12:00:23 am »
I found this odd:
I don't think the rpm's would change dependent on cylinder deactivation.  I was just thinking that Honda geared it higher to compensate for less power when running on 3 cylinders.
