Thanks to Bill Jarvis on Flickr I have the following information from my body tag and serial number.
Body tag:
63 = 1963
V = V8 (could be either 259 or 289 but the engine id says 259)
Y = 4-door sedan (could be either of 2 wheelbases)
6 = Lark Custom (top trim level for the regular 113-inch wheelbase)
Serial number:
63 = 1963
V = V-8
C = Canadian-built (Hamilton ON)
Reading the engine identification number I now know it is a Canadian built 259 cid V8 producing 180 hp @ 4500 rpm from 1963. So strong possibility it is numbers matching. The air cleaner went on the engine and the valve covers were cleaner up. Over spray on the radiator from when it got painted. Not sure why the inside of the fenders are red. Primer perhaps and the previous owner never painted them? Seems to make more sense than the car being previously red. It is a bit of a hodgepodge with the tail lights and hubcaps from a 1962 model. Good thing it will be driver level rather than show car.
The filthy rear section was bugging me so I gave it a basic wash.
The rear window had some residue from a long missing stick on panel which looked much better once removed.
Going through the electrical the signals, headlights, brake lights all worked. Wipers moved a bit and stopped. I really need lubricate the linkage then wet down the windshield before trying again. The horn did not work. I connected the horn its self to the battery and that worked. The steering wheel button wiring and mechanism looked in good shape and without corrosion. I suspect the relay is the culprit but need to verify. Not sure the Mexican blanket works in the car or not.
