In case you didn't catch this in the news few weeks ago, there is a significant and current problem courtesy of VW....
The fuel tanks on MK7 Golf, GTI, SportWagen, Jetta, A3 contain a faulty part - "suction jet pump". When this part fails, you won't be able to fill up the tank. The pump will frequently kick back after pumping few litters of gas like the tank is full. You also hear a gurgling noise coming out of the tank and eventually smell gas around the car. This is not new or unique to VW - I've seen videos and posts for similar issue for other brands, but this is something happening on many VWs now.
VW had an early recall on some GTI/R in US and Canada where they replaced the fuel tank. Some time ago they extended the warranty for this issue to 15 years /242K km (my case). However, there is a new recall that just came out end of Feb for the same issue. The recall is not yet effective so the dealers are not acting on it, but rather do the repair under the extended warranty. According to some owners, the culprit is a $30 part which you can order from the dealer and it's replaceable, but as per service procedure, the dealers are replacing the whole tank at the moment.
Nothing unusual so far. However, when this part fails, it automatically takes with it the Evap Charcoal Canister as the canister fills up with gas which destroys the filter inside. This part
is NOT covered under extended warranty, so you have no choice but to replace it out of pocket to the tune of over $1,800 in parts/labor/tax. The part itself is $1,400+tax.
I was talking to the service manager at my dealership and he said that on every single one out of many they fixed, had to replace the charcoal canister as there is no way to avoid getting gas in it when the suction pump fails. The
rhetorical question is, and I don't expect Patrick to answer
, why doesn't VW cover this part as well right of the bat?
Sure, people got eventually reimbursed for it, but you can imagine the hassle and waste of time associated with it... I'm bracing for it as I will probably kick off the process next week....
