Author Topic: What did you do to your car today?  (Read 2923515 times)
  • Carma: +1253/-7198
Re: Re: Re: What did you do to your car today?
« Reply #2300 on: April 19, 2014, 07:08:48 pm »
Got the oils changed (diff, transfer case, transmission), replaced brake pads and tires balanced on the Tundra.
What did the tranny fluid change run you if you don't mind me asking?  Did they drop the pan or how do they perform the change?
I paid for fluid only, my brother did all the work.
No need to drop the pan, but the tranny procedure is a wild one because it has no dipstick, it looks like this:
- drain it first (drain plug),
- put in 4L of trans oil through the fill plug,
- put trans into temp sensing mode: short two pins on OBDII connector (4-13 I think), start the truck, move gear lever to D and keep switching from D to N until "D" light cams on for 2 sec and turns off, put trans in P and wait for "D" light to come on again - this means the trans oil is between 36-46C (again, I think that's the range),
- if "D" light starts flashing the temp is above 46C - too hot,
- open overfill plug on the trans - this will remove the excess oil - until the oil trickles down, close the plug,
- that's it. Easy eh?
I think I've got all the steps, google it to make sure if you'd like to do it yourself.  I'm sure the dealer can simply connect the truck to the diagnostic comp and read the temp instead.
That still doesn't get all the dirty fluid out of the torque converter and all the lines, does it?
I think it does not, we got only just under 4L out of the tranny. But this was the procedure given by Toyota, so I'm hoping they know what are they doing :)
There's still at least as much old fluid in the tranny then. No access point/drain plug for the converter by chance?
Offline ipolski
  • Carma: +12/-29
  • Cars: 540i-6M, Passat Wagon, Tundra, MDX
« Reply #2301 on: April 19, 2014, 07:38:48 pm »
None that I'm aware of.
Offline Scaerio
  • Carma: +193/-127
  • Cars: 2013 Volvo C30 T5; all my exes: 2005 Suzuki Aerio SE, '02 Renault Clio, '93 Volvo 850 GLT, '78 MB W-123 230
« Reply #2302 on: April 19, 2014, 11:11:42 pm »
Made it boost a certain someone's G37S that decided to kill its battery in revenge for its owner abandoning it while he spent two weeks in sunny Cancun...
I'd rather be car-poor than house-poor...
Offline Solstice2006
  • Carma: +245/-468
  • Cars: 2008 Hyundai Entourage, 2007 Buick Lucerne
« Reply #2303 on: April 19, 2014, 11:23:40 pm »
installed a second car seat to the Mazda5.  Will get to the Odyssey in a few days.  I am tired, and mom is even more tired!
Offline dkaz
  • Carma: +289/-388
  • Flip flop
  • Cars: 12 Mazda 5 GT 6MT
« Reply #2304 on: April 19, 2014, 11:55:36 pm »
Never mind what you did to your car today, is there an addition in your family?
  • Carma: +245/-468
« Reply #2305 on: April 20, 2014, 12:20:51 am »
Yes!!  ;D
See, http://www.autos.ca/forum/index.php/topic,87503.60/topicseen.html
Offline Julie
  • Carma: +359/-366
  • Gender: Female
  • Cars: nb miata, nc mx-5, e92 m3, mk6 gti
« Reply #2306 on: April 20, 2014, 03:15:48 pm »
Cleaned the interior of the Baby Miata after a long winter. I forgot to take pics but I wanted to mention that I bought this about a year ago on Spock's recommendation and have been good use of it for the cars and the house.
I believe he has the original 'green machine'.
Then we took her for a drive in the countryside.  ;D
Offline wing
  • Big Wig
  • Administrator
  • Carma: +279/-320
  • If you ain't first ... you're last!
    • Drivesideways
  • Cars: 2009 Lexus ISF, 2009 Lexus LX570,2011 Audi A5 Touring Car
« Reply #2307 on: April 20, 2014, 04:02:54 pm »
Is that a steamer?  I've been thinking of getting one as they are invaluable for cleaning carpets.  Works well?
Offline quadzilla
  • Carma: +391/-634
  • Cars: 2022 Rock'n Rolla Nightstalker
« Reply #2308 on: April 20, 2014, 04:49:22 pm »
Put the bike carrier on. A job that should take only 15 minutes took 45 minutes. :banghead:
Offline Snowman
  • Carma: +702/-1347
  • “It’s never crowded along the extra mile.”
  • Cars: Cars: 2012 Audi TT-RS. 2011 Toyota Venza AWD.2004 Honda S2000 Bikes: Giant Defy Avdvanced 0. Giant Talon 29 "hardtail"
« Reply #2309 on: April 20, 2014, 04:50:16 pm »
Ohh... I like that.
« Reply #2310 on: April 20, 2014, 05:06:14 pm »
I have one...It's not a steamer. Truthfully, some top shelf automotive carpet cleaner like DP and a plain old shop vac works better
Offline Snowman
  • Carma: +702/-1347
« Reply #2311 on: April 20, 2014, 05:15:34 pm »
I would rather use steam than some chemical spray.
Offline wing
  • Big Wig
  • Administrator
  • Carma: +279/-320
    • Drivesideways
« Reply #2312 on: April 20, 2014, 05:32:45 pm »
Ah not a steamer, I'd rather steam
« Reply #2313 on: April 20, 2014, 05:35:38 pm »
Top shelf chemical is safe though. But steam is nice...But usually expensive.
Offline Julie
  • Carma: +359/-366
  • Gender: Female
« Reply #2314 on: April 20, 2014, 06:32:38 pm »
Not a steamer but the model I have - the ProHeat one - heats the liquid and it seems to work well.
My sense is that it works well for the price. I think I got it for around $70.
EDIT:
- What I like about it: You can spray the heated liquid detergent onto the carpet (as much as you want) and then brush it in as much as you want. (I like being able to work it in with lots of liquid and heat.) Then you can suck the carpet dry with the suction in the turbo brush. The machine is also well designed and easy to clean (including the brushes)
- What isn't practical about it: You need smaller brushes for the crevices/ smaller areas.
Does anyone know of a high quality steamer that isn't too expensive?
« Last Edit: April 20, 2014, 06:38:55 pm by Julie »
« Reply #2315 on: April 20, 2014, 06:40:48 pm »
No...But I suppose one needs to define "expensive"
Offline wing
  • Big Wig
  • Administrator
  • Carma: +279/-320
    • Drivesideways
« Reply #2316 on: April 20, 2014, 06:43:27 pm »
Sounds the same as a shop vac with a squirt bottle of hot water.
Offline Julie
  • Carma: +359/-366
  • Gender: Female
« Reply #2317 on: April 20, 2014, 07:11:58 pm »
Not more than $500? I'm thinking a good steamer could be used to clean a lot of things (windows, appliances, bathrooms, etc.) I'd be willing to pay $500.
  • Carma: +245/-468
« Reply #2318 on: April 20, 2014, 09:22:46 pm »
Maybe I don't know enough about cleaning or steamers.  But windows and steamers?  The pros use a mild detergent, and a good quality squeegee.  I can see for appliances, as the stuff can get caked on... Bathrooms I guess for the ceramic tile/tub area...
  • Carma: +245/-468
« Reply #2319 on: April 20, 2014, 09:23:41 pm »
My Dad has had the for 3-4 years, uses it for the motorhome.
