Author Topic: Cold weather shifting in Golf R  (Read 3718 times)
Online JohnnyMac
  • Carma: +110/-455
  • Cars: 2022 Honda CR-V Sport, 2022 Honda Civic Si, 2020 Toyota Rav4 Hybrid XLE (traded in), 2020 VW Jetta GLI (Traded in), 2010 Hyundai Santa Fe Limited (sold), 2016 VW Golf R (Sold)
« on: February 15, 2017, 09:10:45 am »
This is my second winter with my manual Golf R and this winter has been a much harder one.  Last year I didn't notice any difference in shifting gears when it was cold out.  This year there has been times when I first start the vehicle that I can't get it in gear, especially reverse.  This only occurs when it's -15 out or colder and if I start the vehicle and let it warm up for 5-10 minutes it's a non-issue.  My question is should this be occuring on a new vehicle (under 12,000kms) and other than letting it warm up before trying to move it is there any alternatives?  Has anyone else experience this issue.  I should also note that I do not have a garage currently and my Golf R did not come with a engine block heater (and I'm scared to know how much one would cost to put in).  Should I be mentioning this to the dealer and take it in for them to look at?
Offline Mike
  • Carma: +172/-99
  • Lurker
  • Cars: A Beater and an Ascent
Re: Cold weather shifting in Golf R
« Reply #1 on: February 15, 2017, 09:15:08 am »
It's most likely the fluid freezing up. Not becoming a solid block of ice, but becoming sludge like. My 2004 RX-8 was horrible for this. As soon as it dipped below -20 getting into any gear basically required double clutching and a lot of elbow grease. My 1990 MX-5 was not a fan of cold shifting either.
My WRXs didn't have this issue and neither does the Mazda2. I guess it's hit or miss depending on the car, design, fluid, etc.
Offline Gurgie
  • Carma: +308/-516
  • Cars: 2019 Honda Passport Touring, 2006 SLK 55 AMG
« Reply #2 on: February 15, 2017, 09:18:15 am »
You could take it to the dealer & complain... that might get them to change out the fluid. I always found going into 1st & then into reverse helped in these situations also.
You live everyday. You only die once....
Online JohnnyMac
  • Carma: +110/-455
« Reply #3 on: February 15, 2017, 09:28:28 am »
The problem with taking it to the dealer will be they'll want to see and experience the issue before they do anything.  It's a bit of a hassle to park my vehicle there overnight and not have it for the next morning.  I don't enjoy just "muscling it" into gear as it feels like I would do damage.  It feels like trying to put it in gear without having the clutch peddle pressed fully.  It's really difficult to put it in gear, but when I let it warm up for awhile it's not an issue.
Offline tpl
  • Carma: +298/-675
  • Cars: 2022 Taos
« Reply #4 on: February 15, 2017, 09:30:48 am »
Replace the gearbox oil with a high performance synthetic like Amsoil. RR will know which one.
The most radical revolutionary will become a conservative the day after the revolution.
Offline Sir Osis of Liver
  • Carma: +1376/-1726
  • Ramblin' man
  • Cars: 2017 KTM DUKE 390, 2019 VW Jetta GLI 35th Anniversary
« Reply #5 on: February 15, 2017, 09:49:19 am »
We haven't been as cold as we usually get, but it has hit -30 a few times. The Passat's shifter gets pretty stiff, but nothing I'd consider out of the ordinary compared to the manual Subaru I had out here.
Different transmission to the Golf R though.
On some great and glorious day the plain folks of the land will reach their heart's desire at last, and the White House will be adorned by a downright moron.
H. L. Mencken
Online JohnnyMac
  • Carma: +110/-455
« Reply #6 on: February 15, 2017, 10:00:24 am »
Have you had any issues getting your Passat in gear when it's that cold out?  Do you keep your vehicle in a garage?  Do you use a block heater?
Online JohnnyMac
  • Carma: +110/-455
« Reply #7 on: February 15, 2017, 10:02:46 am »
Yeah I'm thinking that would be the quickest fix for this issue.  Question is which is the best for cold weather?  Should VW be covering any of this under warranty?  How much should doing such a change cost?  Also what kind of gearbox oil does my Golf R come with from factory, it might be synthetic from the factory like the engine oil, in which case how much of an improvement could I possibly see from a fluid change in the gear box?
Offline EV-Light
  • Carma: +125/-1490
« Reply #8 on: February 15, 2017, 10:06:50 am »
take it to VW, it's still under warranty!
having said that, I did a quick search online and it does seem like a common problem with VW manual transmission - some people mention replacing the oil with synthetic (totally assume the trans oil was already synthetic...). Mind you these reports were mostly from GTI owners, so not sure if it is the same transmission.
Offline Ex-airbalancer
  • Carma: +729/-1584
  • Cars: 2011 Silverado 1500 LTZ ext ended cab , 2013 Lexus RX-350 F Sport
« Reply #9 on: February 15, 2017, 10:11:25 am »
Are you  using Tadalafil  ???  ;D
Offline tortoise
  • Carma: +235/-453
« Reply #10 on: February 15, 2017, 10:11:56 am »
I find it helps to let the car idle for a 5 or so minutes before taking of.  That gives the fluid time to warm up a little.
Only the slow and dim know where they're going in life, and seldom is it worth the trip. - Tom Robbins.
  • Ramblin' man
« Reply #11 on: February 15, 2017, 10:49:39 am »
Getting into reverse can be a bit balky when it's really cold. Usually a double clutch and it pops in. I do keep it in the garage overnight, which gets down to about -15 at the worst. It's outside all day.
The car doesn't have a block heater, which still ticks me off.
  • Ramblin' man
« Reply #12 on: February 15, 2017, 10:52:10 am »
 ;D
Offline OliverD
  • Carma: +254/-768
  • Cars: 2011 BMW 328i Touring, 1998 Jaguar XJR, 2024 Mini Cooper S
« Reply #13 on: February 15, 2017, 10:55:25 am »
Don't think I've ever owned a car where the shifter didn't initially feel a bit different when it was really cold out. I wouldn't worry about it too much. I think at best you can expect the dealer to change the transmission oil but they'll likely just replace it with whatever was in there in the first place.
  • Ramblin' man
« Reply #14 on: February 15, 2017, 10:58:28 am »
Toyota fwd transmissions were stiff and with the weak synchros would be pretty crunchy until they had some heat in them.
Offline EV-Light
  • Carma: +125/-1490
« Reply #15 on: February 15, 2017, 11:06:03 am »
yeah...! I always remote start my vehicle so it's warmish when I get there, gives time for all the moving parts to warm up a bit. Also plug when it's -15C and below...it makes a huge difference!
Offline Great_Big_Abyss
  • Carma: +267/-457
  • Cars: 2019 Mazda CX-5
« Reply #16 on: February 15, 2017, 12:54:23 pm »
Check compatibility with your R's transmission, but lots of people swear by Royal Purple.  Apparently it contains magical properties that enhances your transmission's 'smoothness' and makes it easier to get into gear, especially in colder weather.
Offline draghon
  • Carma: +20/-27
  • Cars: Mine [07 Civic SI coupe] Wife [23 Sienna XSE AWD]
« Reply #17 on: February 15, 2017, 01:08:14 pm »
The 6 speed in my civic is harder to shift when its really cold out and hasn't had a chance to warm up yet. I switched to redline synthetic MTL long ago which definitely improved the shift feel overall.
« Last Edit: February 15, 2017, 01:38:30 pm by draghon »
ex rides: 93 Aerostar XLT AWD
wife ex rides: 07 Wave base, 11 Tiguan Comfortline with sport package, 14 Acadia SLE II AWD
« Reply #18 on: February 15, 2017, 01:16:32 pm »
Also as mentioned, double clutching is your friend.  Doubt VW is going to pay for an tranny oil change.
Me, I'd be adding lower radiator hose heater.  Those things are fantastic providing there is room for it.
Offline Brig
  • Brig
  • Carma: +396/-1400
  • Gender: Female
  • Class Clown, Moderatrix and Resident Hag
  • Cars: 2016 Mazda CX-3 GS AWD
« Reply #19 on: February 15, 2017, 01:54:00 pm »
That's what she said.
