^^ Modern ABS is pretty good, but I doubt you’d want ABS on an early Miata.
I had to pull the ABS fuse on my ‘99 Civic when I tracked it, because it scared the everloving
out of me on the bumpy track. I’d be braking hard into a corner, hit a bump, and suddenly lose the brakes for a half second or so. Not fun!
I think the system just couldn’t cycle fast enough. Pull the fuse, and all was fine over the same bump.
And it sucked for winter driving as well. Had lots of panicky moments rolling up to a stop sign at like 4 km/h with the ABS chattering away and the car barely slowing down, even on good winter tires.
Modern systems are much better. No major complaints with the GTI.
