Author Topic: Pressure washer recommendation  (Read 3793 times)
  • Carma: +169/-337
Re: Pressure washer recommendation
« Reply #20 on: June 30, 2021, 09:52:34 am »
I've got an older electric Ryobi. It's ok, doesn't always go to full pressure for some reason, or takes a while to get there (air lock?)
The biggest annoyance is the stiff plastic hose, awkward to work with. Should check to see if it is replaceable, if I can sort the pressure situation
Well changed out the hose for a 50ft Flexzilla, much more flexible and the longer reach over the stock 25ft was handy
Undoing the gun and letting the water run for a minute got rid of the air locks
Hose was not cheap but it's like using a whole new washer
« Reply #21 on: June 30, 2021, 10:06:45 am »
Also if you are using an extension cord , that will effect the performance of any electrical device
  • Carma: +117/-436
« Reply #22 on: June 30, 2021, 11:39:22 am »
Do you have noticeable friction losses?
  • Carma: +169/-337
« Reply #23 on: June 30, 2021, 11:57:10 am »
Didn't seem to at all
Going by this guy, that's to be expected: https://www.youtube.com/watch?v=C9cMVYzHgDg&t
Offline redmont
  • Carma: +1/-0
  • Cars: 09 civic, '16 f150
« Reply #24 on: July 27, 2021, 01:11:17 am »
I have a john deere pressure washer that I bought a few years ago. It works well.
  • Carma: +310/-6811
« Reply #25 on: July 27, 2021, 06:58:11 am »
I stick with Karcher.  Parts are easily available such as the guns.
  • Carma: +117/-436
« Reply #26 on: July 27, 2021, 10:46:04 am »
Am I the only one using gas? Honda engine with Karcher pump is hard to beat IMO.
  • Carma: +242/-779
« Reply #27 on: July 27, 2021, 02:22:48 pm »
I have a slightly bigger Ryobi I bought last year.   Cart handle and wheels on it
It seems to be fine with a few hours on it now.   No real problems with hoses or fittings.
It does take a few seconds to get the water flowing through it before firing it up, that's so the pump doesn't die AFAIK.
So far, I would buy it again over the Simoniz junk I've had before
https://www.homedepot.ca/product/ryobi-1800psi-1-2-gpm-electric-pressure-washer/1001093453
I was using it at the cottage and the gun now won't shut off and leaks from the handle, something blew inside or is stuck open.  Might just be dirt as it's strained, but not filtered lake water. But it's a PITA and I'll have to replace or repair the gun/sprayer
