I have a question for the CX-5 owners.
I leave my 2023 CX-5 wipers set to rain sensing position. They work fine however..... If the windshield is completely covered in rain at start-up the wipers do not do a sweep. I tested it and if I drive away and maneuver at low speed through a parking lot I can drive a few hundred feet (vision impaired) before they kick in. Once they start they function well and react correctly to moisture on windshield. It is just getting them to kick in initially that is the issue.
So because I do not want to drive without seeing properly I have to turn the wipers off and then back on to rain sensing wiper position at start up just to get them started. That can't be right.
I suspect this may be signs on a defect in my system. I am interested to hear if other CX-5's have this issue.
Mine work the same way as yours.
My 2010 Mazda5, 2012 Mazda3, 2016 Mazda3 and 2020 Mazda3 worked the same way.
I always turn off the auto wipers and then immediately turn them on.
Is a matter of getting used to how Mazda auto wiper work.
Nothing to worry about.
My 2016 had the worst system and they stoped working in heavy rain and had to have the relay replaced. There was a recall on it after I had mine fixed.
