Author Topic: I hope this isn't a sign of things to come.  (Read 350254 times)
Offline whaddaiknow
  • Carma: +185/-4812
Re: I hope this isn't a sign of things to come.
« Reply #840 on: May 04, 2015, 12:25:22 pm »
Sounds more like contaminated rotors or uneven deposit of pad material on the rotors. If the rotors were actually warped, I think the shimmy would happen whenever the car is moving, not just when the brakes are applied.
I've been fighting with brake judder on the new mtb. Cleaning the pads and rotors and taking time to bed them in helps, but brakes still have that "grabbing and releasing" feeling, which can come and go depending on how hard I pull the lever.
What Heli said.
My Berlin taxi does the same thing. It is not consistent though. It was very pronounced when I got the car but it almost completely went away just occasionally happening with moderate deceleration now. It was bad enough for me to consider new rotors/pads.
OEM rotors/pad aren't the best on Mercedes. Numerous reports of the same issue on Mbworld.org for W212.
Northernridge
« Reply #841 on: May 04, 2015, 12:54:20 pm »
What Heli said.
Thanks for the post. I suppose mine is so subtle as to almost say intermittent as well.
Offline See3PeeO
  • Carma: +3/-17
« Reply #842 on: May 05, 2015, 04:11:07 pm »
Bought out my ML550 at the end of the lease a few months ago.  Still under full warranty but its been fantastically reliable so far over 40 months.  Still looks like new and I enjoy it every day.  May trade it on the new GLE 500e next year.
Offline sailor723
  • Carma: +416/-1000
  • Cars: '17 BMW X5 Xdrive35i, '11 BMW 328iXdrive,
« Reply #843 on: August 14, 2015, 01:51:33 pm »
I finally got around to getting the Blind Spot warning system fixed again. It was yet another $800 sensor (although only one this time rather than the normal two).......thank goodness for extended warranty. By the time I got in I'd been having an intermittent CEL on for about a month. That turned out to be a "left intake port end position sensor".  The part has to be ordered so back to see my friends in the service dept again when it comes in.
Old Jag convertible...one itch I won't have to scratch again.
Offline johngenx
  • Carma: +758/-938
  • Cars: 2009 Toyota Corolla, 2004 Toyota Highlander V-6 4WD, 2001 Subaru Forester, 1994 Mazda Miata
« Reply #844 on: August 14, 2015, 04:55:06 pm »
That sounds like something they made up.  Then I thought "no, it's German."
Offline Fobroader
  • Carma: +1424/-2113
  • Cars: 2022 Honda Ridgeline, 2021 Lexus GX460, 2018 Kawasaki Versys X300
« Reply #845 on: August 14, 2015, 05:02:04 pm »
 :rofl: I thought the same thing.....left intake port end position sensor.....is that right beside the hydromatic digilator??
Lighten up Francis.....
Offline Sir Osis of Liver
  • Carma: +1376/-1726
  • Ramblin' man
  • Cars: 2017 KTM DUKE 390, 2019 VW Jetta GLI 35th Anniversary
« Reply #846 on: August 14, 2015, 05:02:31 pm »
Next up, the "left intake starboard end position sensor". Then the right port and starboard end position sensors.  ;D
On some great and glorious day the plain folks of the land will reach their heart's desire at last, and the White House will be adorned by a downright moron.
H. L. Mencken
Offline mmret
  • Carma: +240/-570
« Reply #847 on: August 14, 2015, 05:20:37 pm »
Real thing!
http://ww2.justanswer.com/uploads/Chezario/2011-05-15_123610_w906_remove_install_intake_port_shutoff_sensor.pdf
Seems like its related to something called "EKAS position sensor".
The engine in question is one of those symmetric V6 designs with two intake manifolds, hence the "left" part I am guessing.
You can't just have your characters announce how they feel.
That makes me feel angry!
Present: 15.5 V60 T6 + Polestar, 17 MDX
Sometimes Borrow: 11 GLK350
Dark and Twisted Past: 13 TL AWD, 07 Z4 3.0si, 07 CLK550, 06 TSX, 07 Civic, 01 Grandma!
Offline sailor723
  • Carma: +416/-1000
« Reply #848 on: August 17, 2015, 08:43:36 am »
No...I did some research and I'm pretty sure it's the port access to the Flux Capacitor.
You know.....where the Dilithium Crystals go?
Offline goodsonr
  • Auto Obsessed
  • Carma: +18/-5
« Reply #849 on: August 17, 2015, 02:16:51 pm »
perhaps its for the chronosynclastic infidibulm detector .. and not the blind-spot detector...
  • Ramblin' man
« Reply #850 on: August 17, 2015, 02:53:14 pm »
Offline Solstice2006
  • Carma: +245/-468
  • Cars: 2008 Hyundai Entourage, 2007 Buick Lucerne
« Reply #851 on: August 18, 2015, 06:40:31 pm »
Was just saying at the beginning of the summer.  "Very happy the A/C works so well in a 10 year old Odyssey!"  Jinxed myself, as it stopped working Sunday.  Going to have it checked out Friday morning.
Did a bit of driving on the weekend in the Mazda6, noticed some rattling/crackling coming from the front speaker in the door panel.  It's due to for it's 2nd oil change.  So I will take it to the dealer for an oil change this time, and have them check the speaker.
Offline Guy
  • Carma: +478/-1160
  • Cars: 2021 Mustang Mach-E Premium, 2019 Volvo XC40 Momentum
Offline Blueprint
  • Carma: +169/-232
  • member since way back when
  • Cars: 2024 Mazda CX-90 GS-L PHEV, 2022 Subaru Crosstrek Limited, 1975 Triumph TR6
« Reply #853 on: August 19, 2015, 07:05:52 pm »
Air died in my '03 Ody after 10 years, and the culprit wasn't mechanical. A tiny puncture from a rock in the little a/c rad up front.
Traffic engineer/project manager & part time auto journalist
  • Carma: +245/-468
« Reply #854 on: August 19, 2015, 07:08:54 pm »
Changing the condenser wouldn't be too bad.  Part is cheaper.  If it's the compressor I am screwed!
« Last Edit: August 19, 2015, 07:19:04 pm by Solstice2006 »
Offline Blueprint
  • Carma: +169/-232
« Reply #855 on: August 19, 2015, 07:09:27 pm »
Be very careful when you DIY!!
Offline Blueprint
  • Carma: +169/-232
« Reply #856 on: August 19, 2015, 07:11:20 pm »
Changing the condenser wouldn't be too bad.  Part is cheaper.  If it's the condenser I am screwed!
Yeah, I was afraid of the condenser too, so happy it was only the evaporator!
Offline pi314
  • Carma: +59/-95
  • Cars: VW Golf Sportwagen 4Motion 6MT ;Dearly Departed 2015 Honda Fit EX 6MT
« Reply #857 on: August 19, 2015, 07:43:52 pm »
Solstice be sure to check the relay too... that's what went on nut mom's... relatively cheap fix
  • Carma: +245/-468
« Reply #858 on: August 20, 2015, 04:19:15 pm »
So I just checked the relay.  Looks ok.  After investing some time researching on odyssey forums, and Youtube.  Blower motor resistor is a very common problem.  I don't have a tester.  It only takes 5 min to take it out.  So I went to the dealership to buy the part, and hope that would resolve it.  They wanted $292 with tax! Several online parts stores want between $20-$35! (including RockAuto).  I called the local wreckers, they will give me the resistor and blower motor for $80 tax in.
Once my mechanic determines the problem (hopefully it is the resistor), then I will go get it.
Offline Ron
  • Carma: +2/-2
  • Cars: 2011 Mazda 3 GT, 2012 Mazda 5 GT
« Reply #859 on: August 21, 2015, 08:23:54 am »
If it is the blower resistor then you will not have a variable speed for the air flow. It will just blow the same air at all settings. Obviously no air then I would look at the motor (or fuse). Both are easy repairs I recall, just awkward positioning, have done them 2-3 times on Fords and Hondas.
