On the weekend:
-Replaced rear HVAC control computer and blend door actuator in the 'Slade. > Rear HVCA now fully functional again...Gotta keep the empty seats cool
-Replaced the upper rad hose on the T/A. When I did the rad a couple weeks ago the hose I ordered was wrong(wrong diameter at the thermostat housing end), so I reused the original. New replacement finally came in, in the correct size, so I swapped it over. Easy job.
-Put a new MotoMaster Eliminator Ultra AGM battery in the SLK. The old one was 6 years old and still working fine, but I scored a freebie, so why not. At least this new one is a sealed AGM design, so it shouldn't leak or corrode, and apparently the self discharge rate is lower on an AGM unit - handy for my car that does a lot of sitting.
-Also had a new key shell for the SLK sitting around, so I finally got the courage to take one of my beaten up original keys apart and transfer everything over. Had to transfer the immobilizer chip, circuit board and key blade. Setting the spring load on the key blade was a bit of a pain, but I managed to get it back together and working properly without breaking anything. It's really nice to have a fresh looking key again
-Did little bit of detailing too. Namely the leather on the SLK with some Mequires treatment, and a quick wash for the Escalade.
