So, this should be pretty spectacular. It goes up sometime on January 11th I believe it's at 8am EST, but not positive on that.
https://www.spacex.com/webcastCrew Dragon In-Flight Abort Test (Suborbital)
"SpaceX will conduct an uncrewed In-flight Abort (IFA) Test. This will validate Crew Dragon’s ability to pull crew away to safety in the event of a failure during launch. The capsule will fire its integrated SuperDraco abort motors at the point of maximum dynamic pressure (max q), on ascent, and pull itself safely clear of the Falcon 9. It will then detach from the trunk, deploy its parachutes, and gently splashdown 34km downrange, in the Atlantic Ocean. Within an hour, the spacecraft will be recovered from the water and brought back to Port Canaveral by Go Searcher along with other members of SpaceX’s east coast fleet.
As a result of extreme aerodynamic forces, the Falcon 9 rocket is expected to disintegrate immediately after the abort, which will be performed at approximately T+01:06."
Oh yeah, there's a launch scheduled for tonight as well:
Monday, January 6 at 9:19 p.m. EST, or 2:19 UTC on January 7, for its third launch of Starlink satellites
