The STi has a lot more over the WRX than the extra ponies. The suspension is much stiffer and designed for really, really fast travel. The DCCD system is fantastic.
Not anymore. Racecomp engineering put both 2015's on the dyno and compared the suspension. It's nearly identical now.
previous generation, it was very different the numbers.
Taken from nasioc:
STI fronts are mono tube
WRX front is twin tube
BOTH REARS are TWIN TUBE. (notice graphs look almost the same)
measurements below are for WRX
bump front 48.1 mm (1.89 inch)
droop front 88.9 mm (3.5 inch)
44.5 mm front bumpstop
bump rear 51mm (2 inch)
droop rear 66 mm (2.6 inch)
55 mm rear bumpstop
_____________________________________
STI front spring rates 5.8K
STI rear spring rates 5.3k
WRX front spring rates 5.8K
WRX rear spring ratees 5.2K
STI front sway bar 24mm
STI rear sway bar 20mm
WRX front bar 23mm ( measured on press car FEB 2014)
WRX rear bar 20mm
