I remember test drove an 6 speed manual GTS before, on paper this car is awsome -- 8000rpm, 6 speed manual, light weight ....
but I found out the gears a way too tall - I remember on second gear 8000rpm is above 110 Km/h .... this kills all the fun, as if anyone want to feel the VVTi-L, you can to go beyond legal speed limit , and if you want to use 3rd gear, you will be in 140+ range which is impossible in most place in Canada.
Civic Si is much better, 2nd gear max out below 90km/h and 3rd gear is 120km range, so ones can play between 2 and 3rd gear all day long without getting into trouble ....
