Ms. Flinter has had a 2007 SX4 JLX AWD (Manual) for over 8 years now and ~150K km.
IMHO its not in the same category and Toyota/Honda in terms of reliability. Outside of regular maintenance, in the 8+ years of ownership, we've had to replace:
- 2 front struts,
- Leaking seal in rear differential.
- 2 wheel bearings,
- alternator replaced 2 times,
- water pump,
- A/C compressor clutch.
- Recently, we are starting to hear some exhaust rattles which is about par for the course for an 8 year old car.
Regarding the alternator being replaced 2 times. Suzuki/Fiat positioned the alternator very poorly. It's best accessed from below the car or through the front wheel well. I suspect the low position results in lots of water, salt, sand etc. flying up around the alternator and a lower life.
The slip/grip AWD system is no match for a Subie but with 4 good winter tires, the car is still very capable in winter. Over the years we've driven it in some horrible conditions, and we've always felt confident that it will get you there.
Fuel economy is not as good as many expect (9-10L/100km), but I don't think it's fair to compare this car to sub-compacts like Fit, Yaris, Fiesta etc. Given the size and weight of the vehicle, I think it's more appropriate to compare it to cars like the Golf, Matrix, Impreza.
Ms. Flinter has commented many times about the smallish fuel tank that results frequent pit stops. I understand that in 2010 the fuel tank was made slightly larger in the AWD model to try and address the range concern.
The engine and the six-speed manual transmission were updated in 2010. While the newer J20B shares the same bore/stroke with the earlier J20A, I've read that it uses a different block, different compression ratio, many changes to the internals and adds variable valve timing. I also understand that the J20B is a more fuel efficient engine and when combined with the newer six-speed manual the EPA (combined) fuel economy rating improved significantly. The six-speed was a welcome change as the older 5 speed does rev a little too high for our liking when cruising on the highway and that change can clearly be seen in the highway fuel economy ratings.
Here's our list of our likes/dislikes:
Likes
- The chassis and body has a very solid/substantial feel like the German brands.
- Reliability has been decent
- It is surprisingly fun to drive for an economy car.
- AWD has been very useful in the winter.
- Attractive styling and a pretty decent interior for an economy car. The interior has also held up very well for us.
- Small footprint makes it a very maneuverable daily driver.
- Hatchback design has lots of utility and cargo room.
- High roofline with lots of glass gives the car an open airy feel.
- Raised seating position similar to a CUV/SUV makes entry/exit very easy.
- Good bang for the buck.
Dislikes
- Fuel economy has not been great compared with similar sized FWD cars on the market. This might be less of an issue on the 2010+ models.
- Small fuel tank leads to frequent stops at the gas station. Again, this might be less of an issue on the 2010+ models.
- It could use a taller 5th gear or a 6 speed to improve fuel efficiency on the highway. This has been addressed on the 2010+ model.
- The car would be much better with another 20-30hp.
- The manual shifter is not up to the same standards that I've experienced in Honda products. Not sure if the newer 6 speed manual has improved in this area.
- The thick A pillar and triangle shaped side windows creates a bad blind spot for drivers of a certain height.
- The rear seats do not fold flat to the rest of the cargo area. On the plus side, you can flip forward the entire rear seat assembly which resulting in a large flat cargo hold.
- The turn signals are virtually inaudible.
- Obviously we are concerned about Suzuki's decision to leave the North American market and how that might impact service and parts going forward.
