More bad news for my coworker. Vehicle now has 166k kms on it (6k kms outside of the extended warranty).
We were driving to Red Deer a couple of weeks ago. The vehicle randomly cut power and momentarily would give a A/T temp high warning and it would disappear, along with the check engine light. I was thankful that at least we made it there and back. It didn't do it on our way back.
Took it into the dealership who has had it for almost 2 weeks. Here's the latest:
TECH INSPECTED FOR CHECK ENGINE LIGHT ON DASH AS REQUESTED. NO LIGHT WAS ON DASH. WAS ADVISED TO DRIVE VEHICLE AT HIGHWAY SPEEDS. UPON TEST DRIVE, TECH NOTICED THAT WHEN VEHICLE WAS APPROACHING ABOVE 5,000 RPMS, THAT VEHICLE WOULD BEGIN TO CUT FUEL AND ENTER A "LIMP MODE" CAUSING "A/T TEMP HIGH" LIGHT TO FLICKER. WHEN TECH RELEASED THROTTLE, FOUND THAT VEHICLE HAD RETURNED TO NORMAL DRIVING PERFORMANCE. TECH BROUGHT VEHICLE INTO SHOP AND INSPECTED TRANSMISSION FLUID LEVEL AND FOUND TO BE GOOD AT THIS TIME. TECH THEN TRIED TO TAKE VEHICLE ON A SECOND TEST DRIVE WITH DIAGNOSTIC SCANNER CONNECTED TO VEHICLE TO SEE WHAT DTC IS PRESENT WHEN LIGHT IS BEING SHOWN. NO CODES WERE STORED DURING INSPECTION. TECH DROVER VEHICLE EXTENSIVELY FOR LONG PERIODS OF TIME AND WAS ABLE TO PRODUCE EMISSION LIGHT ON DASH. DTC P0685 "POWER CONTROL CIRCUIT/INTERNAL CIRCUIT MALFUNCTION". FOLLOWED THROUGH DIAGNOSTIC PROCEDURE DOING BATTERY TEST AND FOUND TO BE GOOD AT THIS TIME. PROCEDURE LED TO REPLACEMENT OF PCM. TECH REPLACED PCM WITH KNOWN GOOD COMPONENT AND STILL FOUND THAT VEHICLE IS PERFORMING THE EXACT SAME. TECH STARTED A TECH LINE FILE AND WAS ADVISED TO INSPECTED MULTIPLE DIFFERENT CONNECTORS AND GROUNDS OF ENGINE BAY AND CABIN OF VEHICLE. (C212, B2, C206, C104, C101, C4, B1, C41, B41, C103, B40, C1, 201, A46 UNDER HOOD FUSE BOX, A/T TEMP SENSOR) INSPECTED ALL CONNECTORS AS PER ADVISED AND FOUND VISUALLY TO LOOK GOOD AT THIS TIME. TECH WAS THEN ADVISED TO MOVE WIRES WHILE VEHICLE WAS ON AND IN DRIVE (STATIONARY) AND SEE IF POSSIBLE OPEN WIRE IN PCM WIRES CAUSING LIGHT TO TURN ON. WAS UNABEL TO PRODUCE A/T TEMP HIGH LIGHT ON WHILE VEHICLE IS STATIONARY. AT THIS TIME, THE NEXT STEP IN DIAGNOSIS IS TO HAVE ENGINE HARNESS REPLACED. PRICE FOR COMPONENT IS $1096.22 PLUS $1820.00 INSTALLATION BEFORE TAXES. PARTS ARE CURRENTLY IN MONTREAL AND CAN BE ORDERED UPON CUSTOMER APPROVAL.
He is taking this up with Acura Canada given the shear number of problems he has had. Definitely got a lemon. He just has the worst luck with cars despite taking good care of them. I think he is just going to lease from now on. He certainly won't dump this kind of money into it and would likely trade it in.
Lol FJC anybody?
