Thanks for the pricing info. It's more than I hoped - but pretty much what I thought - it would be. Maybe Ford Canada will offer incentives once the initial glow wears off? They've already piled them on the regular Focus, but if the ST is in limited supply maybe they won't have to do the same...
I assume the Focus ST will have the same monstrously large turning diameter as the Focus Titanium with 18" wheels (~ 40 feet). Too bad, I'd like a hot hatch to be nimble, and nothing is less nimble than a U-turn which becomes a 3-point turn... Not a deal-breaker, but very annoying.
Confused by this, I did a check on Kelly Blue Book and it says a 2012 Focus Titanium has a turning radius of 36 feet vs. 35.1 ft. for my wife's 2006 Jetta which is, I suppose, normal (ie; it feels fine, and doesn't make wide turns). The Cruze has a turning radius of 36.4 ft., the Civic is 35.5 ft.
Perhaps I'll look stupid for asking this, but does changing to a different wheel on the same car without modifying anything else increase the turning radius, and if so, by a significant degree? I can't see how it would change, unless the tire rubs up against a fender stopping it from turning. Which would cause EXTREME tire wear!
Or was the Focus 'problem' mentioned above fixed some time ago?
In other words, can anyone verify what the current situation is?
EDIT: According to this copy of a US spec sheet, the turning radius IS large, 39.4 ft.
http://www.fordstnation.com/images/misc/2013_focus_st_specs2.jpg
