Author Topic: Rattle in the back end - 07 Camry LE  (Read 327 times)
Offline jtmann
« on: August 17, 2011, 06:08:59 pm »
Hello. I have a 2007 Camry LE and have noticed a rattle in the rear of the car when I drive over bumps. It is not normal noise from bumps but seems to be an issue with the car. I know that the car has collapsible rear seats that hook/lock in to holders – could this be the cause/have you heard of this being an issue with this model?
If not, what could be the other causes?
Thanks very much!
  • Carma: +81/-89
Re: Rattle in the back end - 07 Camry LE
« Reply #1 on: August 17, 2011, 10:42:03 pm »
If the noise is from the inside, you need someone sitting in the back to track it down as you drive...
Offline Juke1
  • Carma: +2/-27
« Reply #2 on: August 18, 2011, 09:01:55 am »
You might want to look through the 73 pages here to see if anything sounds like yours.  http://townhall-talk.edmunds.com/direct/view/.ef106e9/537
« Reply #3 on: August 18, 2011, 06:46:57 pm »
REmove trunk liner, remove spare tire, jack, wheel wrench and lug nut key if applicable and then test ride.
Offline laspalmas
  • Carma: +0/-5
  • Cars: 2012 Hyundai Elantra Limited
« Reply #4 on: August 23, 2011, 08:25:39 am »
Thanks very much!
I had a similar problem with my Camry. Have a mechanic check the suspension rubber bushings, I mistakenly replaced a shock thinking it was the culprit but it turned out to be simply a bushing - a cheap repair, noise was gone for good.
Je serais triste comme un Marxiste, et frustré comme un Počte maudit, si tu me quittait, pour un joueur de ballon-balais, mon amour.
Plume Latraverse
Offline Gardiner Westbound
  • Carma: +13/-8
« Reply #5 on: August 25, 2011, 09:44:11 pm »
+1
Worn sway bar bushings will do that. It's an inexpensive repair.
See attachment.
« Last Edit: August 25, 2011, 09:48:16 pm by Gardiner Westbound »
