Author Topic: Toyota Prius C  (Read 2101 times)
Offline Ontariodriver
  • Carma: +0/-10
Toyota Prius C
« on: July 19, 2011, 05:33:38 pm »
« Last Edit: July 26, 2011, 11:46:12 am by Ontariodriver »
Offline Arctic_White
Re: Toyota Prius City
« Reply #1 on: July 19, 2011, 10:31:26 pm »
Looks decent; would be perfect commuter car!
  • Carma: +5/-4
« Reply #2 on: July 20, 2011, 11:46:15 pm »
Small, light, affordable and even more fuel efficient = WIN for Toyota.
Offline 1TSX
  • Carma: +28/-26
« Reply #3 on: July 20, 2011, 11:58:10 pm »
It looks like a CR-Z and Prius mix.
Mine: 2004 Acura TSX
Offline Ice
  • Carma: +4/-3
« Reply #4 on: July 21, 2011, 05:03:33 pm »
Probably more like a CT200h only a bit smaller and with less luxury and more regular Toyota thrown in the mix.
It may end up being the cool Prius... but Toyota rarely does things like that. Then again it's new CEO might help turn things around a bit.
Offline shanwchin
    • Printinghost.com
Re: Toyota Prius C
« Reply #5 on: August 02, 2011, 12:34:16 pm »
Hi, its very decant model ..really sucks me .. :)
  i like its front as compare to BMW 6 series...
  • Carma: +0/-10
Re: Toyota Prius C
« Reply #6 on: October 19, 2011, 06:17:01 am »
ttp://carscoop.blogspot.com/2011/10/new-toyota-prius-c-leaked-brochure.html
This is it folks the baby Prius pretty nice car. The front looks a bit Hyundai.
Online DKaz
  • Carma: +37/-11
Re: Toyota Prius C
« Reply #7 on: October 19, 2011, 11:17:28 am »
Just looks like a Yaris hybrid. Still, Toyota can do something really cool and put a manual transmission in it...
Offline Ice
  • Carma: +4/-3
Re: Toyota Prius C
« Reply #8 on: October 19, 2011, 11:10:58 pm »
I thought they use some sort of special planetary gear arrangement for the hybrid drive. Can a manual even work with that?
I thought the concept had some nice lines to it. It seems more cluttered now which is too bad.
Offline G35X
Re: Toyota Prius C
« Reply #9 on: October 20, 2011, 01:35:08 am »
I thought they use some sort of special planetary gear arrangement for the hybrid drive. Can a manual even work with that? “ – IceAndFire
No, Toyota’s planetary gear system is very elegant as it can handle one, two or three power sources rotating at various rpm without requiring clutches. It can also turn either of the two electric motors into a generator without any additional mechanism. The gearset is a kind of CVT and does not require additional transmission.  Honda, Hyundai and Infiniti, on the other hand, are using different hybrid system, in that ICE output shaft is connected coaxially (in tandem) to an electric motor, technically the output of which can be connected to either manual or automatic transmission in conventional fashion. In the case with manual transmission it requires a usual clutch. When coasting or stopping the electric motor turns into a generator to recoup energy, in which case a clutch to disengage ICE and electric motor(generator) would be a good idea for more efficient energy recovery. Hyundai and Infinity are using this clutch system.  Honda cannot put a clutch between the ICE output shaft and the pancake flywheel-motor and instead closes all the valves to reduce drag.  I think eventually Honda will also put a kind of clutch (sleeve type?) to make its hybrid system more efficient.
The tandem ICE/motor design is more desirable for sports oriented vehicles because the speed (feel and sound) of the ICE/motor is in sync with the acceleration of the vehicle.  Toyota’s FT-86 and Subaru’s twin as well as future Mazda RX-8 replacement are supposed to be “sports” type. Because of the short length of their ICE I think eventually they will all come with a hybrid version with the tandem ICE/motor design.
  • Carma: +0/-10
  • Carma: +5/-4
Re: Toyota Prius C
« Reply #11 on: November 16, 2011, 11:37:03 pm »
I think it's easily one of the hottest and sexiest among the new hatchbacks. If it doesn't have numb steering it'll become a hit with the young crowd and then everybody looking for efficient and sporty looking transportation.
Online rrocket
  • Carma: +81/-89
Offline Sir Osis of Liver
  • Carma: +41/-40
  • You call this an angry mob?
Re: Toyota Prius C
« Reply #13 on: November 16, 2011, 11:45:36 pm »
Just in Japan? What about the rest of the world? Ogiso cites “currency and production issues” that might delay the arrival of a Prius C on other shores. A Prius C  is tied to where Prius hybrids are made, and that’s Japan, Thailand and soon China. The expensive parts, the power trains come solely from Japan. The high yen doesn’t make Japanese exports low cost. That’s one thing Ogiso can’t engineer.
Not exactly encouraging.
Carl Sagan
Offline ajay
  • Carma: +4/-30
Re: Toyota Prius C
« Reply #14 on: November 17, 2011, 01:08:15 am »
Apparently it has a low center of gravity and is quite the handler
can't wait to read reports on it . 157 inches long , thats only 8 1/2 inches longer than the 2nd gen crx si
which was the next best thing to a bike in my mind .
Very promising .
Offline ajay
  • Carma: +4/-30
Offline Ice
  • Carma: +4/-3
Re: Toyota Prius C
« Reply #16 on: November 22, 2011, 06:01:01 pm »
I know the Prius is supposed to have a funky interior but even as a self professed geek... it just isn't appealing. The outside isn't too bad and it sounds like the handling will be quite impressive. I think they are a good plan for Toyota... we'll see how it pans out but I think it'll be a good thing for them.
Offline ajay
  • Carma: +4/-30
Re: Toyota Prius C
« Reply #17 on: December 02, 2011, 01:49:49 am »
  quote -- " vehicle's svelte curb weight " ,
thats encouraging
http://ca.autoblog.com/2011/12/01/toyota-aqua-concepts-tokyo-2011/
  • Carma: +0/-10
Re: Toyota Prius C
« Reply #18 on: February 09, 2012, 06:08:24 am »
Offline Seafoam
  • Carma: +7/-1
Re: Toyota Prius C
« Reply #19 on: February 09, 2012, 06:38:01 pm »
U.S pricing I assume? I think on here somewhere I read we will get hosed for $21,000 not $18,950. ::)
