So the Z4 makes a regular "clunking" noise when going around corners and on bumps. Not 100% sure if it is from the front or the rear. If you knock on a piece of MDF you'll hear something vaguely similar. I thought it would be a loose sway bar or something.
Took it to a garage and they said it was the front control arm bushings. I thought that was rather odd, as the steering seems totally fine and the car is perfectly straight under braking.
Can a bad front control arm bushing actually cause such a headache? The OEM ones are $200 each (!!!!!), but aftermarket can be had for about $90/pair. Maybe they will toss it under what little warranty I have left...
