So I went up a few sizes on tires. 205/50-R17 -> 235/45-R17.
The tires came mounted and pressured at the max for the tire, something like 50 psi.
I put them on, drove around for a bit, it felt nice and tight. Later I dropped the psi to the recommended 32.
The drop in pressure made a noticeable difference in driving feel.
Regardless do I always run the recommended PSI marked inside the door or do I have to go higher because the tires are wider?
Cheers Z
