Author Topic: Winter beater - car for 2 winters only  (Read 3408 times)
Offline UmroAyyar
Re: Winter beater - car for 2 winters only
« Reply #20 on: July 23, 2010, 11:24:19 am »
This has a 3.3L V6.
1997 Dodge Intrepid - 160k km - e-test, safety - $1800
What to check in this car? going to check this tomorrow.
Private or dealer?   Best bet, obviously, would be something you can see the repair history of.
For certain, if it has the 2.7 the engine has been replaced at some point.  My brother has a 98 or 99 that had the engine go at around 63,000 km... cost him over $5k because he couldn't prove maintenance/oil changes etc were completed etc...so Chrysler basically told him to suck it.
He's had the car since new, and other than the engine issue, its been pretty reliable.
ˇʇnɥs ɥʇnoɯ ɹnoʎ dǝǝʞ oʇ ǝɔuɐɥɔ ɐ ssıɯ ɹǝʌǝu
Offline UmroAyyar
« Reply #21 on: July 23, 2010, 06:31:30 pm »
Checking these two cars tomorrow.
All of these are with safety and e-tested.
2001 Hyundai Accent GL Sedan - 176000km - $1700
1997 Dodge Intrepid V6 - 160000 km -  $1800
  • Carma: +81/-89
Offline UmroAyyar
« Reply #23 on: July 23, 2010, 10:12:09 pm »
There are quite a few decent cars with 5spd manual transmissions. Mrs and I both will be driving the car so manual trans is out of question for now.
We are thinking of getting an auto trans for now and spring for a manual later for the second car.
Echo $1900.
http://www.autotrader.ca/used_cars_Car_details/MISSISSAUGA_Ontario_2000_TOYOTA_ECHO_2209571.html?srcID=25&frnID=10228609&prv=Ontario&r=40
Offline dr_spock
  • Carma: +10/-4
« Reply #24 on: July 24, 2010, 12:00:31 am »
Manual driving lessons only costed me about $150.   Less if you have a willing friend.   :)
Offline UmroAyyar
« Reply #25 on: July 24, 2010, 08:29:40 pm »
Test drove 3 cars today. Pulled the plug on ...........
1997 Chrysler Intrepid 3.3L V6, 162000km for $1850. Car Proof report, E-Test, Safety, new brake pads, oil change included. This car had only 2 owners, got traded in.
So, thank you everyone for all the helpful tips :P.
Now, the real help is needed, what to do with this car to keep it running properly?
Online tpl
  • Carma: +32/-31
« Reply #26 on: July 24, 2010, 09:14:05 pm »
Hmmm park it all winter and drive the Camry?  Seriously, are they one of the Chryslers with a transmission that needs to be serviced regularly with fresh fluid to keep it alive?   I sorta remember from many threads that the minivans with the same or similar powertrains had transmission problems..
Artic or Maritimestorm will know.
Offline UmroAyyar
« Reply #27 on: July 24, 2010, 09:24:14 pm »
Sir tpl,
The Camry was fabulous, it was sold off to buy two cars for the family.
This is my winter beater, this must run in winter and if it survives, endure my daily grind on Gardiner Expressway.
Later, the Mrs. will get a better car whose name can be used with the word reliability in the general vicinity.
So, for the other guys who know these cars. Are the transmission issues need to be dealt with regular trans fluid changes?
  • Carma: +8/-1
« Reply #28 on: July 24, 2010, 09:28:40 pm »
From APA.ca:
CHRYSLER Concorde, Dodge Intrepid (1993-1997), Eagle Vision (1993-1997)
* Recall covering 1993-1997 models with 3.5L engine: the fuel injection delivery system may leak fuel from some of the defective seals. This could result in fire. Replace nitrile rubber “o-rings” with “o-rings” made of an improved material. Fuel rail will also be evaluated and replaced as required.
http://www.apa.ca/template.asp?DocID=23
Offline UmroAyyar
« Reply #29 on: July 24, 2010, 09:31:28 pm »
From APA.ca:
This one is a 3.3L V6 161hp engine - base model.
The 3.5L 214hp was only available in the ES trim.
Offline dr_spock
  • Carma: +10/-4
« Reply #30 on: July 24, 2010, 11:48:20 pm »
Do you have the service records for the Intrepid and the owner's manual?   That's a good place to start to see what upcoming maintenance may be required.   Are the tires and battery good enough for a couple of Toronto winters?
Offline UmroAyyar
« Reply #31 on: July 24, 2010, 11:59:27 pm »
Tires are BFGoodrich Momentum. Most likely I will get a set of winter tires and steel wheels.
Checklist
1- Battery Check (got a battery charger with cables)
2- Spark Plugs
3- Engine Oil change
4- Transmission Fluid check
5- Brake Fluid Check
more...?
Offline airbalancer
  • Carma: +92/-89
« Reply #32 on: July 25, 2010, 08:00:31 am »
CAA membership  ;D
Offline Careener
  • Carma: +10/-2
  • Cars: 2012 Mustang V6PP
« Reply #33 on: July 25, 2010, 09:16:09 am »
+1 on the CAA membership.
I suggest you start over at allpar to find resources for technical info, cheap parts etc.
Former Rust Enthusiast
Offline Careener
  • Carma: +10/-2
« Reply #34 on: July 25, 2010, 09:20:21 am »
Offline UmroAyyar
« Reply #35 on: July 25, 2010, 09:47:13 am »
Here's the link
http://www.allpar.com/fix/
This is brilliant info. Thanks a bunch.  :cheers:
Online Julie
  • Carma: +79/-188
  • Gender: Female
« Reply #36 on: July 25, 2010, 10:34:05 am »
Congrats Umro.
Offline maritime_storm
« Reply #37 on: July 26, 2010, 08:12:59 am »
I'm yet to meet automatic transaxle that couldn't benefit from regular fluid changes more so on certain Chrysler transaxles(Intrepid/Neon/Caravan). That having been said at the mileage on this one, have the fluid changed but do not use a chemical flush and use only ATF+4. At the mileage on this old girl, the chemicals may cause issues. Alot people kill slush boxes 2 ways; 1. never changing the fluid 2. Using the wrong fluid.
Online tpl
  • Carma: +32/-31
« Reply #38 on: July 26, 2010, 08:14:47 am »
There! I knew that Maritime would have the wisdom needed here.
Offline UmroAyyar
« Reply #39 on: July 26, 2010, 11:50:46 am »
Flush or just change - that is quite a conundrum for me because I have owned a car this old before.
Based on what you are saying. Avoid flushing the fluids, just change them.
I am planning to change the oil and transmission fluid immediately.
Next up, Brake Fluid, Power steering fluid, Engine Coolant, all these before winter.
What about differential oil?
