Around 156000 km or almost 100k miles
Car does not blow hot air until it is driven, once I come to a red light for extended period of time with fan at full speed, air temperature will start to decrease until it becomes cold and this repeats.
I know most people would say this is low coolant problem.
I checked the overfill tank. It's beyond the full mark and up to the top of the filler neck. ie. I can see the coolant when taking the cover off the filler.
After warming up the car and having the fan blow at max. The fan blower in front of the engine do not turn on. I felt the coolant return line that goes from the top of engine back to the engine(I think that's the flow) did not get warm at all.
I have a few questions before I take it upon myself to fix it or take it to my mechanic.
1. Is the fact that the coolant is up to the filler neck an indication of a clog?
2. Can bad thermostat cause this?
3. The coolant has not been replaced before and from the manual, it says doesn't need replacement till 192000km.
4. What colour is the coolant supposed to be? I know toyota's is red, but not too sure about honda.
5. Should there be a burnt smell in the coolant? If I have a headgasket problem, shouldn't there be no coolant in the overfill tank?
Any other suggestions of what to check would be great. Thanks all.
1. Is the fact that the coolant is up to the filler neck an indication of a clog?Did you ever see the fluid level at the normal mark? That is one hard design to read I gotta say. When the motor is cold I would remove the excess coolant to get it down to the "max" level. Siphon I guess. Did someone fill it up to the top with windshied washer fluid?
Can bad thermostat cause this? Just at idle?
The coolant has not been replaced before and from the manual, it says doesn't need replacement till 192000km.The coolant is good for 5 years so they say. In reality it is shot after 4 years in any vehicle. "5 year" coolant is an EPA thing.
What colour is the coolant supposed to be? I know toyota's is red, but not too sure about honda.Pink
Should there be a burnt smell in the coolant? If I have a headgasket problem, shouldn't there be no coolant in the overfill tank? Not really. If the head gasket leak is on the exhaust side then yes the coolant will go out the exhaust. Otherwise it will mix with your oil. Is your oil milky in colour?
You have not talked about the engine temp gauge. What is that doing when you come to an idle?
Could be weak water pump. However, you are at the point of a timing belt change. If you plan on keeping the car I would get it done asap. At which point you get a new rebuild water pump and of course a total coolant change along with a new thermostat.
You could try changing out the thermostat. That would be the easiest and cheapest thing to do right away. But I think you need a water pump so it's part of a T belt job.
