Author Topic: Will seafoam foul spark plugs?  (Read 3147 times)
Offline dbradley
« on: February 11, 2010, 01:05:00 pm »
Hi Folks,
I took my 2001 Suzuki Esteem (~200k km)into the garage because I was getting poor gas mileage.  They Replaced the O2 sensor, did a wheel alignment and replaced the spark plugs.  I ran a can of seafoam through the gas tank to clean the injectors, but I was considering adding some seafoam (as directed) through the brake booster vacuum line as well, just to be sure everything is up to snuff.
I assume I won't foul the plugs doing this?  I thought I ask here just to be sure.
Thanks!
D
Offline ovr50
  • Carma: +9/-120
Re: Will seafoam foul spark plugs?
« Reply #1 on: February 11, 2010, 01:10:43 pm »
What is seafoam??
and
Offline vdk
  • Carma: +17/-12
  • Carma: +9/-3
  • Resident Dingus
« Reply #3 on: February 11, 2010, 02:22:31 pm »
Is a product like that necessary or even safe to use on a modern engine, especially when added through a vacuum line?  ???
Offline ovr50
  • Carma: +9/-120
« Reply #4 on: February 11, 2010, 02:36:38 pm »
What is seafoam??
http://www.youtube.com/watch?v=dQP51za9BmM&feature=related
OK, got it now, Google is my friend.
I wouldn't use the stuff myself; but I know very little about it. Seems to be more useful for older technology tho.  ???
Offline Leviathan
« Reply #5 on: February 11, 2010, 04:28:42 pm »
http://www.escape-central.com/1forum/showthread.php?s=8f76dabd76234a052212bde46119c411&threadid=33350
2006 3.0 52000mi I just warmed up the engine , then hooked a hose to where the brake booster hose neets the intake manifold. I put the hose in the can of seafoam and CLANK CLANK CLANK!!! I SHUT THE MOTOR DOWN IMMEDDIATELY. Tried to restart and it wont turn over. Just a click at the starter. W T F????????? Will have it towed to ford. this f ing sucks.
Seafoam   :rofl2:
« Reply #6 on: February 11, 2010, 04:35:51 pm »
..well i'll be a SEA MINKEY..................looks like the OLDE TOP OIL additive stuff(REDEX...et al) we put in Brit cars to decoke    followed by an Italian TUNE UP...............which twin did TONY!!!! ;D
Offline dbradley
« Reply #7 on: February 12, 2010, 08:32:14 am »
seafoamsales.com/motor-treatment.html
It's used to clean injectors and remove carbon deposits from the engine in various locations.  Not a lot of users here it would seem :P
  • Carma: +9/-3
  • Resident Dingus
« Reply #8 on: February 12, 2010, 08:39:08 am »
Most folks here don't have a problem with their vehicles having carbon build up.  :skid:  :rofl2:
  • Carma: +37/-70
  • Shake the Baby
« Reply #9 on: February 12, 2010, 10:29:56 am »
I've heard it's a good product, but have no knowledge of using it personally.  I do know that if you add it through the vacuum line, do it slowly.
Offline maritime_storm
« Reply #10 on: February 14, 2010, 08:38:07 am »
You can run it through a brake booter hose but their is a real danger of hydrolocking the engine(thus ruining it). You're better off running seafoam through the tank. An alternate method would be to use it as a piston soak. Remove the plugs, add a quater bottle to each of the 4 cyls, let it soak overnight. The next day put rags over each cyl, crank engine(without the spark plugs in it) to remove the excess. Re-install the plugs and take her for a hard run down the highway to clean things out. Reality is though, if you're running fuel injector cleaner regularly, and don't baby you're vehicle, then you shouldn't have carbon build-up in the cylinders to begin with.
  • Carma: +37/-70
  • Shake the Baby
« Reply #11 on: February 14, 2010, 10:06:33 am »
From what I understand Seafoam makes a product called "Deep Creep" in an aerosol can, this is the product you are supposed to spray in the intake manifold by removing a vacuum line.  It cleans out the intake manifold and intake tract where the injector cleaner can't reach.
You can also pour their  "Motor Treatment" product in the intake, but it would take more care than the spray can to avoid hydro-locking.
Carbon buildup in the intake can lead to hard starting, poor fuel mileage  and other problems.  I wonder if this would work on the Audi direct injection engines having this intake tract buildup?
  • Carma: +81/-89
« Reply #12 on: February 14, 2010, 10:13:38 am »
Seafoam   :rofl2:
Operator error, not the product.  You just can't allow the engine to suck up a whole can REALLY fast through a brake booster line.  I've never used the product myself, but have witnessed it being used (smoke show, anyone?) and others swear by it.  YOu just have to be careful how you introduce it to the engine.
Offline No H2O
  • Carma: +0/-2
  • Alps Adventurer
« Reply #13 on: February 17, 2010, 09:27:24 pm »
What is seafoam??
I must have missed something because I really didn't get what that video was trying to prove or show.
Offline No H2O
  • Carma: +0/-2
  • Alps Adventurer
« Reply #14 on: February 17, 2010, 09:28:40 pm »
I ran a can of seafoam through the gas tank to clean the injectors.
You can also use Chevron Techron additive.
  • Carma: +81/-89
« Reply #15 on: February 17, 2010, 09:32:49 pm »
My favorite off the shelf product for this use.
  • Carma: +37/-70
  • Shake the Baby
« Reply #16 on: February 17, 2010, 09:42:49 pm »
Haven't found it locally in years.  Where is it? ???
  • Carma: +81/-89
« Reply #17 on: February 17, 2010, 09:51:26 pm »
I only find it in the US.  Want me pick you up a couple next time I go??
  • Carma: +37/-70
  • Shake the Baby
« Reply #18 on: February 17, 2010, 10:00:05 pm »
No, thanks anyway.  I looked last time I was across the border at a Wal-mart, but they didn't have it, that's where I used to get it years ago in Canada.
Offline Roddy
« Reply #19 on: February 18, 2010, 12:03:41 pm »
It's snake oil. I wouldn't recommend you put that stuff anywhere near your engine.
