CRZ 2,720 lbs.
Insight 2,744 lbs.
Civic 2,588 lbs.
Fit 2,489 lbs.
This is the part that is nearly unbelievable. They take a Fit, Shrink it, remove back seats, rear doors and still manage to come out 200lbs heavier. Totally destroying the Power to weight ratio.
Instead of trying to do everything with one car and failing at everything, they should have done two versions of the car, better optimized for its mission. The CVT sucks for fun, so optimize it better for fuel economy, The Manual clearly doesn't work that great with the hybrid system so ditch the hybrid and optimize for fun. Note this still only give two options to federalize, test.
Version One: Using the smaller
Insight engine and CVT to optimize fuel economy. Then it should have at least matched the Insight fuel economy. Another question. How they heck is it just as heavy as the 4 door, 4 seat Insight? Anyway maybe the Insight engine is lighter and it could lose a few pounds and have a slight performance advantage over the Insight and at least as good fuel economy.
Version two: 6speed Manual,
No Hybrid 1.8L. This version must be at least 250lbs lighter. So it should have very nice performance and decent (Civic like) fuel economy.
I am stunned how bad the current "
jack of no trades" design is.
