Pages: [1]   Go Down
Author Topic: chrysler 300m  (Read 760 times)
miztakin
« on: September 28, 2009, 11:43:33 am »
Having signal light problems. they work a few times then they quit. Same with the 4ways. tried switching the fuses had no luck. Any Suggestions
inco
Vehicle: 2011 Explorer XLT 4WD, 2011 Subaru Forester Touring
« Reply #1 on: September 28, 2009, 02:51:30 pm »
So what do you have to do to make them work again? Fuse - if so you likely have a short along the way and will hve to trace your wiring.
jamie1
Vehicle: 2009 Acura TSX, 2001 Toyota RAV4 AWD 5sp.
« Reply #2 on: September 28, 2009, 08:27:47 pm »
Sounds like the multi-function switch. Cheap and easy to replace. Split the column covers,unplug and unscrew the switch.
miztakin
« Reply #3 on: September 29, 2009, 01:32:43 pm »
Thanks those are two great ideas. I'm gonna try the multi function switch first sounds like that might be it. Thanx again
Roddy
« Reply #4 on: September 29, 2009, 09:46:14 pm »
Yes, try the flasher unit first.. that is the most likely cause
Pages: [1]   Go Up
Page created in 0.036 seconds with 26 queries.
