...so it's not the brake fluid..........
By E-brake do you mean the EMERGENCY or HAND BRAKE?....if so facto follow it's trail i imagine there is a switch/sensor near the hand brake lever...is it functional..jammed...dirty....and does the cable system initiating the E brakes on the rear
brakes function smoothly or is it too jammed dirty or seized up.....cable broken/stretched or come un tethered...
? GET DOWN AND DIRTY fella..............look see,,,,,,,,,,,,
ALL THIS CAN BE DONE FROM THE COMFORT OF YER ARSE ON THE DRIVEWAY......
