This is the best rundown on all the different types of antifreezes I have found:
http://www.motor.com/magazine/pdfs/082004_04.pdf2-EHA is the special Dexcool additive that seems to cause all the controversy about seals:
The inhibitor 2-EHA poses another issue: It's a plasticizer (softens plastic), so it has been blamed for coolant passage gasket leakage. Softening (and the resulting distortion) was reported by Ford, which encountered gasket leakage problems when it tested a DexCool-type formula on its V8 engines. Ford also saw similar issues with other gasket materials. That killed the OAT coolant idea for Ford, which had used a DexCool-like coolant in the '99 Cougar V6.
