Welcome to the club! I'm sure you'll enjoy it (I still do after 4 years). What is the build month on yours? The only "problem" I had on mine was a rattling glove box, replaced under a TSB. I also had a firmware update for a hard shift in second gear on cold.
There is also a recall on the driver door and a second recall for a rusting pipe on the tranny.
Make sure you have those checked out and addressed.
Other than that, the car was solid and problems free.
The premature rusting in the rear wheel well might be another thing to look into. Yours is almost new and not driven much in the winter so perhaps it should not show any rust, but it's better to preemptively treat those areas before the problem occurs.
- My car was built Dec 2004. (do not know if that is good or bad)
- Purchased in May 2005.
- Have paperwork showing 2 recalls were done.
1) Recall SSP75 for doors (I think the locks)
2) Recall SSP74 Trans Oil Pipe.
No rattle in glove box but car does tend to shift a little hard into 2nd. Not severe so may be normal. I do not know.
Now for the biggest disappointment. I checked the lips of the rear wheel wells and sure enough there is rust (a fair amount of it). The back of the lips were caked with mud. Cleaned out the mud and smeared the back and the lip with grease.
I cannot believe I missed it. I checked all the door bottoms. There was not a sport of rust anywhere so I must have let my guard down and stopped looking. In my defense most of the paint was still there so it looked white. But it was all lifted off the lip and ready to fall right off.
In warmer weather I will sand down and try and paint it. Will re-grease and get Dura-Check done on car (which has never been done before).
All I can say is wow. A 2005 that has hardly seen winter with rust. Hard to believe on a car used so little. Everything from Mtce records to wear on interior and pedals supports the low Kms. It is obviously a real weak spot on these cars.
I am disappointed to discover the rust but other than that I must say that in driving the car for the past day I have been very impressed. The interior quality, features, power and driving experience is very good.
Lets hope there are too many other disappointments in store for me.
