Poll
why is my suburban failing the etest
02 sensor
0 (0%)
egr valve
0 (0%)
could it be the idle
1 (100%)
Total Members Voted: 1
Author Topic: 1993 suburban  (Read 1755 times)
Offline labatts
1993 suburban
« on: February 17, 2009, 12:49:42 pm »
My 1993 suburban is failing its etest terribly.
my mechanic who is a door knob set my idleup high.I was told that the idle cannot be adjusted .Is this correct and is that why it is failing.Please help
I have put new plugs,wires cap and rotor,also new 02 sensor.
  • Carma: +9/-3
  • Resident Dingus
Re: 1993 suburban
« Reply #1 on: February 17, 2009, 01:50:51 pm »
What part(s) of the test is it failing (NOx, CO)?
Offline Honda Owner
Re: 1993 suburban
« Reply #2 on: February 17, 2009, 02:13:44 pm »
Could be many, many things. First, how many KM? Over 200,000, don't waste your time, it is not worth it in most cases.
But......if there is no "check engine" light I would replace the catcon. OTOH if it is a 350, they are notorious for poor OEM valve seals which let oil in the combustion chambers and lead to high HC and CO levels. If the vehicle is using more oil than it should, like a litre every 2000 km or more (and it should burn none, these are tight engines) you are probably looking at valve seadl or a new engine. You would have to ask yourself if this is worth it for a 16 year old vehicle? My answer would be "no" since a proper engine replacement is at least $3000.
Re: 1993 suburban
« Reply #3 on: February 17, 2009, 10:38:08 pm »
To replace the valve seals is not all that expensive a job on these engines as the parts are less then $80.00 for the whole set. The labour is the biggest part but it dosen't take all that long to do them. The engine will smoke on startup until its warmed up if this is the case.  :)
Offline Honda Owner
Re: 1993 suburban
« Reply #4 on: February 19, 2009, 12:38:46 am »
Yup, but it is an easy job on a small block. I have seen cases so bad they smoked all the time. Other than that one small thing, a 350 is practically indestructible.
Online tpl
  • Carma: +32/-31
Re: 1993 suburban
« Reply #5 on: February 19, 2009, 06:35:32 am »
Do we need TWO threads on this?    It is in the Technical questions section as well.
Re: 1993 suburban
« Reply #6 on: February 19, 2009, 10:44:24 am »
..Labatts is BLUE inna face aboot it????????????? ??? ::) :P...all the newbies want FREE advice to FIX their Suburban WOES..... :rofl2:...Get a RED SPORTS KAR and a HOT CHICK.....
