Poll
Question: Van Back fires
van runs poor - 0 (0%)
van makes noises - 0 (0%)
Total Voters: 0
Pages: [1]   Go Down
Author Topic: !994 Plymouth Voyager  (Read 1760 times)
1994plymouthvoyager
Noob
Vehicle: 1994 plymouth voyager
« on: January 04, 2009, 11:40:56 pm »
I have a 1994 Plymouth Voyager. It has been back firing lately. Could this be the timing? Just today it ran out of gas and now, it won't go more than 60 km/hr. It starts fine, idles fine and runs ok up to 60 km/hr. but just won't go over 60. It has been running ok lately, but even at 80-100 km/hr it will "chug"/"sputter" and or back fire. Any thoughts? Does it need a good tune up, spark plugs, wires etc.?
barrie1
« Reply #1 on: January 05, 2009, 09:02:23 pm »
Welcome 1994plymouthvoyager to the forem. I would have your timing checked as it sounds like it may have gone out of whack to act like that. I am wondering on the timing belt as it may have jumped a tooth possibly which would acct for the sick behavior of it.  Which V6 engine is it Please as some were better designs then others in this series?  Smiley
rrocket
« Reply #2 on: January 05, 2009, 09:07:22 pm »
^^^^Barrie offers good advice.  But even easier...check the distributor cap and rotor.  If it has never been changed...it's due.  A bad distributor/rotor can cause problems like you describe.  Better yet, it's a cheap fix too.
barrie1
« Reply #3 on: January 06, 2009, 04:29:21 pm »
I had one of them here in my shop about a year ago with a similar problem and is why I know it was the timing chain that had jumped as we tore it down and replaced it here. Did the same thing when started and would not hardly pull its own weight at all. I agree with rrocket tho on the cap and rotor as they are a possiblitiy as well.  Smiley
Honda Owner
Drunk on Fuel
Vehicle: 2009 Honda Accord
« Reply #4 on: January 07, 2009, 02:20:13 am »
If it is a 3.0 V-6 it is almost certainly a head gasket. Whatever is wrong with it, it is not worth spending money on.
Squishy
Drunk on Fuel
Vehicle: Squishy
The goggles, they do nothing!
View Profile WWW
Champion of
More>>
« Reply #5 on: January 07, 2009, 03:25:05 am »
Head gasket causing a backfire?  Is that even possible?
I would check timing, distributor/rotor, wires, spark plugs, anything you can think of that would cause a misfire or otherwise dump unburnt fuel out the exhaust.
The Garage:
barrie1
« Reply #6 on: January 07, 2009, 11:30:41 pm »
If its a head gasket it should start showing signs of moisture in the oil on the dip stick I would think, The white miley looking substance that can form when oil and heated oil mix together. Its actually sulphric acid and can burn holes in your cloths so keep it off of you. That should tell you for sure if its head gasket leak.  Smiley
Honda Owner
Drunk on Fuel
« Reply #7 on: January 08, 2009, 01:56:26 am »
Well, Barrie, the Mitsubishi 3.0 litre V-6 is a total POS anyway. Chrysler lowballed them on the engines and Mitsu responded by building them with a $1.49 day gasket set. Interestingly, in the Japanese made captive stuff we sold we never had any problems with the same engine.
barrie1
« Reply #8 on: January 08, 2009, 10:47:53 pm »
I agree as the 3.0 was not their pride and joy at all but the vehicles were cheap to buy and own while they lasted. Their newer 3.3 and 3.8's are much better designed for sure.  Smiley
Honda Owner
Drunk on Fuel
« Reply #9 on: January 09, 2009, 01:04:38 am »
The 3.0 was not a Chrysler engine. Chrysler did not produce a V-6 and the original Caravans were underpowered. Thus, Chrysler went to Mitusbishi for their 3.0 V-6, which were shipped complete to the North American plants. These motors were expensive and this led Chrysler to develop the 3.3 an iron block and head motor. They are indestructible. In all the time I was at Chrysler, I only saw one fail, from not having a single oil change in 30,000 km.
barrie1
« Reply #10 on: January 10, 2009, 12:52:31 am »
I agree with the quality that was built into them was very good for sure. I have driven them quite a bit for the Baliff and found them to do a nice job actually. I worked as a Car hunter for a while which was quite interesting in its day.  Smiley
Pages: [1]   Go Up
Page created in 0.056 seconds with 34 queries.
