Don't put antiseize on the studs, that will throw off the torque reading. Most shops I have been to either don't torque at all, or use "torque sticks", which in my opinion don't work well at all. The last time I let a shop touch my wheels, I asked them to use an 80-lb torque stick (and watched them use it). As soon as I pulled out of the garage, I went to torque them to 98 ft-lbs with my own torque wrench. The nuts wouldn't budge until 115 ft-lbs on the wrench. The difference between static and kinetic friction is not that much; they were obviously overtorqued even though a stick was used.
There is only one shop I know of that will use a torque wrench and properly torque the wheels off the ground, and that is Go! Glass at Weber and Columbia in Waterloo.
