Yea, I read a test driver from InsideLIne. You can see it here:
http://www.insideline.com/chevrolet/volt/2011/2011-chevrolet-volt-first-drive-and-video.htmlWhat stood out to me was "Volt chief engineer Andrew Farah makes it clear. "The Volt's [battery-only] range is
up to 40 miles.
Most people will get less than 40 miles. A few people will get more than 40."
Once the gasoline engine is fired up to sustain the charge, Farah reckons the Volt will run completely out of fuel — again, assuming you drive in a way that's similar to the EPA's city driving cycle — in another 300 miles. Since the Volt's fuel tank is presently 8 gallons in volume, this overall mileage expectation equates to more than
38 mpg when driving in this "charge-sustaining" mode."
So it seems unless you have less than a 40 mile round trip (who knows how much less that 40 miles it will get on EV mode) that means it's pretty much useless to everybody else, since it only gets ~38 MPG, roughly 12MPG less than a Prius, other frugal car. Did I read that correctly? That once you burn through the EV portion this thing only gets 38 MPG?
Other than that issue, seems like progress is progressing nicely on the test mules.
