* Replace engine oil* and filter.
* Rotate tires,** inspect for wear and adjust pressure
* Service front and rear brakes.
* Inspect parking brake adjustments.
* Inspect tie rod ends, steering gear box and boots.
* Inspect suspension components.
* Inspect driveshaft boots.
* Inspect brake hoses and lines (including ABS)
* Check all fluid levels, condition of fluids and check for leaks.
* Inspect exhaust system.
* Inspect fuel lines and connections.
