Pages: [1]   Go Down
Author Topic: Nissan Versa update  (Read 3097 times)
Schmengie
Drunk on Fuel
Vehicle: 2008 Nissan Versa
« on: April 25, 2008, 07:15:04 pm »
  As promised, here are my impressions so far of my '08 Nissan Versa S Hatchback, Magnetic Gray with Value Option Package, A/T, CoreRacing Evo7 alloy wheels, 8160 km's,
delivery date Sept.15, 2007, purchased from Barnes Nissan, Vernon BC.
  After a little more than 7 months, my experience with the Versa has been excellent, the car has more than lived up to our expectations. No problems whatever so far.
Exterior Impressions:
 I like the substantial look of the Versa; it certainly doesn't come across as a 'small' car in the traditional sense. The car's step-in height and large, wide-opening doors makes ingress and egress very easy, you sort of slide into the car rather than climbing in like you would an SUV or dropping in like my old '00 Neon. You quickly appreciate this feature when transporting elderly or disabled passengers like I do. The large body-coloured door handles feel solid and are very easy to use with gloved hands, but the jury's still out on the microswitch-controlled hatch release. It works well enough, but it's not obvious - you have to look for it and even when you find it, it takes a few seconds to figure out if you haven't read the manual. It can be quite difficult to find and use with gloved hands and for some reason Nissan doesn't include an interior hatch release. I would also prefer the bottom of the hatch opening to be a bit wider, but that's the price paid for styling I guess. The hatch opens high with gas struts which some might find a bit stiff but it does include an integrated pull-down handle. The only other exterior feature I'm not crazy about are the chrome-slathered headlights. A body-coloured treatment would be more attractive IMO. The headlights themselves are very effective, with excellent range and good cut-off.
Interior Impressions:
 The first things most people comment on when they get into my Versa is how roomy the interior is and how good it looks. The quality of the materials and construction is excellent, much better than the price would suggest.There are some unexpected touches that surprised me, including the huge glove box with a big door that has a damped closing mechanism - the door glides open smoothly instead of suddenly dropping and smacking you on the knee. The interior grab-handles also close with an expensive-feeling damped motion - very nice!  With a couple of exceptions, the overall design of the dashboard and interior is attractive and functional. The seats have inboard recliner handles that take some getting used to, but this is because the seats themselves are quite wide and the doors have large map pockets which leave no room to put your hand between them. The controls don't feel cheap or flimsy and are where you expect to find them, with one major exception. The electric mirror controls are on an unlit panel low on the dash next to the driver's left knee instead of on the door where they belong. I'm also puzzled why Nissan doesn't include a standard center armrest since they seem to have gone the extra mile in making the Versa such a comfortable car.
 Rear seat room is exceptional, with at least as much leg room as I remember having in my '00 Dodge Caravan - amazing! The level of comfort back there is very high, at least as good as in front. The rear seatback has a 60/40 split but doesn't fold flat into the floor. The Versa would be truly versatile if Nissan included flip-and-fold seats similar to the Honda Fit.
 The base stereo is Ok, but it doesn't have MP3 capability and only one CD. I expect most people will swap it out, but beware - Nissan charges a fortune for their optional head units, so the aftermarket is the way to go here.
 HVAC controls are straight-forward and effective, more or less what you would expect. The rear window and mirror defrosters  work very well, but stay on longer than necessary.
Driving Impressions:
 Once you get into the driver's seat, you immediately notice the Versa's exceptional outward visibility due to the large windows and rear-view mirrors and the low beltline.The seats are comfortable, but not very adjustable - a height adjuster is standard only on the SL model. Once underway, the engine is quiet and smooth with very little vibration. Sometimes the only indication it's running is the tach - a couple of times I tried to re-start at a stoplight because I thought the engine had died, not a mistake I ever made in my old Neon. The car is very responsive and agile in city driving and very good on the highway, with adequate power for passing and steep grades even with the A/T. I expect the 6-speed manual would be even better in this regard. I can't comment on fuel economy definitively because the winter tires just came off, but it looks like I'm getting somewhere in the high 8L per 100 km's in city driving. Highway mileage on our trip to the Kootenays last Fall was 7.1.
Some other observations:
The Versa's dimensions and capacities are almost identical to the new '09 Toyota Matrix/Pontiac Vibe twins. Most of these dimensions are notably larger than the Yaris-Fit class in which the Versa competes. Some examples:
                                            Toyota Matrix XR (A/T, B Package)                Nissan Versa S (A/T, Value Option Package, ABS)
Wheelbase                                    2600mm, 102.3"                                                              2600mm, 102.3"
Length                                          4365mm, 171.8"                                                              4295mm, 169.1"
Weight                                          1385 kg, 3053 lbs                                                            1248 kg, 2751 lbs
Engine                                           1.8L, 132 hp        1.8L, 122 hp
The Versa's lighter weight gives it a slightly better power to weight ratio than the Matrix, 22.5 lbs per hp as opposed to 23.1 for the Matrix.
The Versa also is better in some key interior dimensions, although to be fair the Matrix is better in others. The differences are negligible except rear leg room where the Versa has a clear edge and cargo volume where the Matrix's greater length makes it the winner. Surprisingly, the Versa has .5 cu/ft more total passenger volume. Similarly equipped, the Matrix costs $19,190 and the Versa $17,498. Is it just me, or is Nissan competing in the wrong market segment with the Versa?
                                                             Matrix        Versa
Front Head Room                             1029mm, 40.5"                                                               1031mm, 40.6"
Front Leg Room                               1057mm, 41.5"                                                               1052mm, 41.4"
Rear Head Room                              999mm, 39.3"        972mm, 38.3"
Rear Leg Room                                919mm, 36.2"        966mm, 38.0"
Total Passenger Volume                    94.2 cu/ft.        94.7 cu/ft.
Cargo volume, seats up                     19.8 cu/ft.        17.8 cu/ft.
edit - pic added
« Last Edit: April 25, 2008, 07:36:23 pm by Schmengie » Logged
slybry
« Reply #1 on: April 25, 2008, 10:03:50 pm »
Nice review. Glad to hear car has given you no problems.
I guess you do not have CVT (I think they are in SL only) so you cannot comment on what that is like in this car.
Living my BMW dream.
PJungnitsch
Drunk on Fuel
View Profile WWW
« Reply #2 on: April 26, 2008, 12:12:26 am »
From the time I've spent in my parents Versa (who purchased theirs from the same dealer) I'd agree with your impressions. It feels like a more expensive car than it is, quiet and solid, and the back seat is huge. You do sit fairly high, something they appreciate being retired and I like as well (being a pickup person). They have the SL with the CVT, and the variable transmission is quiet and works nicely.
They have had theirs for over a year now, with no issues I know of.
Careener
Vehicle: 2012 Mustang V6PP and Mazda 6 Wagon
« Reply #3 on: April 26, 2008, 11:12:31 am »
Thanks for the update. The interior room really impressed me both times I sat in one. The driver was 6'2" and I was in the back seat and am 6'4" and had no problem with legroom. Somehow there was also room for luggage in the trunk.
If looking for a smallish hatch (or not so small)the Versa would be my top pick.
Former Rust Enthusiast
artemmedv
Noob
« Reply #4 on: June 21, 2008, 11:45:09 pm »
Learned to drive on an 07 Versa sedan. Now bought an 08. A great comfortable car with lots of energy and nice design.
Jaeger
Vehicle: 2011 Hyundai Sonata 2.0T 2009 Honda Fit
member
« Reply #5 on: July 07, 2008, 05:11:21 pm »
Thanks for that very detailed review.  I think Nissan has turned out a very fine product with this vehicle.  An amazing amount of interior space wrapped in a very compact exterior package.
Jaeger
Schmengie
Drunk on Fuel
« Reply #6 on: July 07, 2008, 11:38:59 pm »
Jaeger
Thanks, Jaeger. So far, my initial impressions are holding up and then some. We're going to Barkerville in the Caribou-Chilcotin for a few days; after we get back I'll post another update.  Smiley
The Mighty Duck
Vehicle: 2009 Honda Fit Sport
the mighty duck
« Reply #7 on: July 08, 2008, 01:06:38 am »
Your interior impressions match mine from my test drive pretty well to a T.  Very, very nice vehicle inside, especially at this price point.  It's a shame the Versa doesn't qualify for the Federal EcoAuto rebate and BC's own rebate - it's already good value at MSRP, but with another $2000 knocked off it would be the hands-down winner in this segment.
I prefer the driving dynamics of the Honda Fit over the Versa, but did enjoy the Versa - and the one I drove was riding on steelies, whereas the Fit had the optional alloys and, presumably, better tires.  I did find the Fit more punchy, though, which is odd since its down on power and displacement, but overall I thought the Versa made a lot of sense.  Great review!  Smiley
Demosthenes [noun], dem-aws-thene-s
1) (384 BC – 322 BC) the greatest of the Ancient Greek orators
2) pseudonym used by Valentine Wiggin in Orson Scott Card's Ender's Game to alter the events of world history
mwqa
Vehicle: 2004 Suzuki Aerio S
member
« Reply #8 on: July 08, 2008, 12:38:53 pm »
I like the Versa a lot - very comfortable and pleasant to drive.
Haven't they reduced the MSRP on 2009 by $1,000?
Just put the steering wheel in the DOWN position and the drive feels much better - watz up with that??
Schmengie
Drunk on Fuel
« Reply #9 on: July 08, 2008, 02:34:31 pm »
I dunno, but if they did it would:
    1) make the Versa a really killer deal, and
    2) royally me off because my car instantly depreciated by a thousand bucks!  Tongue Cry
mwqa
member
« Reply #10 on: July 08, 2008, 02:44:22 pm »
http://shopping.montrealgazette.canada.com/ROP/ads.aspx?advid=203044&adid=6565576&subid=22381763&type=
No doubt the devil is in the details.
I think both the 2009 S and SL have been reduced.
safristi
« Reply #11 on: July 08, 2008, 02:49:35 pm »
I say "DOUBLY PEAS OFF THA SCHMENGE".............then we can ALL buy one..... Grin TaTa fer now (NOT AVAILABLE  )
AmirVscas
« Reply #12 on: September 05, 2008, 01:13:25 am »
just got my Nissan Versa today..very nice car..love the interior
Pages: [1]   Go Up
Page created in 0.089 seconds with 34 queries.
