Poll
Check engine light CODE 1381 Accord 1999 LX
THE GARAGE
2 (50%)
THE GARAGE
2 (50%)
Total Members Voted: 2
Author Topic: Technical Question  (Read 2510 times)
Offline jay-acura
Technical Question
« on: March 18, 2008, 07:36:13 pm »
 ???....help me honda!!!!!!......i'm sure someone somewhere has had this problem....>>>>it's baffling me and so far 4 mechanics have given me different diagnostics about it.........CODE 1381....means CRANK POSITION SENSOR....engine runs well but hits a little bog sometimes...otherwise it's just a pain in the eye to look at......so each mechanic tells me to change a different part.....i.e........change your distributor......change your wires......change your alternator.....and finally.......get this.......change your computer......it's a glitch coming from your computer........SO FAR THIS HAS ALL PROVEN FALSE!!!!!.....and i've had to put back the parts........HAS ANYONE OUT THERE HAD THIS CODE AND PROBLEM.......PLEASE DO TELL ME WHAT IN THE WORLD IT IS??????......last thing i was told was to change the crank position sensor situated next to the timing belts.....?????........SOSOSOSOSOSOSOSOSOS!!!!
Offline si
Re: Technical Question
« Reply #1 on: March 18, 2008, 07:50:02 pm »
 :notroll:
  • Carma: +81/-89
« Reply #2 on: March 18, 2008, 08:16:00 pm »
Ummm..how about change your crank position sensor?   ;D
Offline Squishy
    • Ford Escape Forums
« Reply #3 on: March 18, 2008, 08:32:54 pm »
^^^^ What he said. ???
The Garage:
Offline airbalancer
  • Carma: +92/-89
« Reply #4 on: March 18, 2008, 09:05:31 pm »
:notroll:
Why would say he is a troll?
I did not trash talk a brand, or person, just wants to fix a problem
  • Carma: +81/-89
« Reply #5 on: March 18, 2008, 09:08:31 pm »
^^^^Hehehe....been tipping a few back tonight?
« Reply #6 on: March 18, 2008, 09:52:39 pm »
Jay-Acura Welcome to the Forum, assuming you have changed the CPS I would suggest looking at all the wires and hoses surrounding this device to make sure none of them are damaged,loose or have holes in them to create any form of leak. Its amazing just how small a leak or problem can create such big time problems in a engine. You could actually go as far as to turn the light off by just pulling the bulb out of it from under the dash if no-body can find it and the car runs well. Could be aslight glitch in the wiring harness as well. Hope this helps.  :)
  • Carma: +81/-89
« Reply #7 on: March 18, 2008, 10:18:52 pm »
^^Barrie...crank position sensor has nothing to do with any leaks, vacuum or otherwise...
Offline jay-acura
« Reply #8 on: March 18, 2008, 10:25:59 pm »
     Thanks to everyone.........i will proceed to change my CPS......but will ask another mechanic.......just in case ........after all........one HYBRID HONDA MECHANIC  told me if it was your CPS........your car wouldn't start???????........seriously,  does anyone really know what's going on here????....any further suggestions will be greatly appreciated.......after all,  this is one heck of a great car........love it!!!!!!!.......it's just a machine ......but finding this little "weasel".......is really tricky.....thanks again to all you honda pros out there....... :)
« Reply #9 on: March 19, 2008, 01:11:44 am »
Yes you are right but they can give readings similar to those items I mentioned as well in its behavior. As it seems 4 different shops have diagnosed 4 different problems on this vehicle so far and none has been right. I would start checking the obvious next which is this type of thing. They can set weird or strange codes due to these type of problems. Some Caddi's like to set a code 51 for example but it actually means nothing at all. Part of other stuff that hasen't gone off yet or moisture in the wrong place.  Have you changed out the CPS as yet?  :)
« Last Edit: March 19, 2008, 01:16:09 am by barrie1 »
Offline jay-acura
« Reply #10 on: March 19, 2008, 11:25:02 am »
     As of right now i have not changed the CPS..........before i do.....would you be so kind as to tell me EXACTLY where it is??????.........someone hinted it was close to the timing belts......is this correct????..........i really don't feel like changing the wrong piece......lol.......thanks again for all the input......JAY
  • Carma: +12/-17
« Reply #11 on: March 19, 2008, 03:10:03 pm »
If you don't even know where the CPS is do you think you should be changing it?  ???
Offline airbalancer
  • Carma: +92/-89
« Reply #12 on: March 19, 2008, 03:26:54 pm »
Nothing wrong with getting your hands dirty and giving it a try
Maybe you should get a manual for your car, also try on a honda nation or what every it is called , someone may have a picture
« Last Edit: March 19, 2008, 03:49:48 pm by airbalancer »
Offline initial_D
  • Carma: +14/-0
« Reply #13 on: March 19, 2008, 03:41:09 pm »
« Reply #14 on: March 20, 2008, 12:13:21 am »
I have to agree with those last few statements as if you don't know what you are doing under the hood then really you should not be there. Definitely replace the CPS to begin with 1st. It will probably solve all your Problems when you do it.  :)
  • Carma: +12/-17
« Reply #15 on: March 20, 2008, 07:02:05 am »
I stand behind my statement. If the OP showed any initiative s/he would have already have the manual and be working on the car already, not asking where is it.
Will the next question be what tools will I need?
Offline Craig
« Reply #16 on: March 20, 2008, 11:01:47 am »
Forget your car.  What's wrong with your keyboard?
Offline Squishy
« Reply #17 on: March 20, 2008, 11:56:45 am »
It appears he is channelling Saf. ???
Offline jay-acura
« Reply #18 on: March 20, 2008, 12:43:17 pm »
       Once again....i take the time to say thank you for your input and savvy......for those who like to take pot shots at me.......i am not a mechanic and i am not changing anything on my own.......i want to be sure no one "takes me for a ride".....i'm sure you all know the terminology........as for my keyboard......it's connected to a great laptop......and it works well......maybe you could stop being so analytical and just answer my question if you can or just spare the sarcasm.......as for an instruction manual.......if i had one ....i would not be asking your advice.......thank you all.
Offline weebl
« Reply #19 on: March 20, 2008, 12:45:47 pm »
Pot shots at your keyboard have everything to do with the people finding your posts difficult to read.  I don't know about others, but if it takes me too much effort to figure out what someone has written, I can't be bothered.
