Author Topic: Yellowing headlight  (Read 1038 times)
Online slybry
Yellowing headlight
« on: February 25, 2008, 04:55:50 pm »
My 2000 Honda Accord has one headlight assembly that is yellowing. The other one is like new.  I noticed it last fall and has gotten worse over the winter. If it was age they both would be yellowing (like all the the old Ford's). I have not examined it too closely yet.
I was wondering if moisture got inside it. If so is it possible to take it out and clean the moisture from inside and restore it.
If that cannot be done I guess will try and find a 2nd hand one from a scrapper.
PS: Any reccomendation for a good source of used parts in Montreal area would be welcome.
Living my BMW dream.
Offline Squishy
    • Ford Escape Forums
Re: Yellowing headlight
« Reply #1 on: February 25, 2008, 05:38:12 pm »
Take a good look at the headlight - if it's on the outside, you should see clear signs of dried out plastic.  There are plastic restoration compounds available, but I'm not sure which ones work well; maybe one of the avid detailers here could chime in.  For preventative measure, you should wax the headlights whenever you wash the car.
The Garage:
  • Carma: +81/-89
« Reply #2 on: February 25, 2008, 05:40:56 pm »
Try some Mcguiars Plast-X cleaner.  Works great
Offline Seafoam
  • Carma: +7/-1
« Reply #3 on: February 25, 2008, 07:38:25 pm »
Yes i second that. It worked great on my father in laws 98 Grand Cherokee and 97 Intrepid plastic headlights.
Online slybry
« Reply #4 on: February 25, 2008, 09:44:03 pm »
    I will look closely but I do not think it is on outside of lens. Why would one turn yellow and the other look like new? Cars I have seen with this problem have both lights looking bad in the same manner.
     That is why I suspect something inside going wrong. Maybe when bulb replace the seal was not properly sealed etc etc.
