I decided to spend some time yesterday draining and refilling the coolant in my wifes' Protege5, since it was a little overdue. I checked the Mazda Service manual and it said the drain/refill capacity was 6.x Litres (I think 6.7L, 7.0L on a dry block and radiator). So I went and bought 2 x 3.87L jugs of premixed coolant and got to work.
Drain completely, including the resevoir.
Refill with water, start engine, get to operating temperature, then stop engine and drain again.
Ensure the 'water' coming out this time is nearly or completely clear. Check.
Now, it said to add the premixed coolant at a rate of 1L per minute, which I guess gives the air bubbles to get out of the system. So, I took 5 minutes to add one jug of coolant (3.8L). Great. BUT, the only problem is, the rad was COMPLETELY full by the end of this. I even had enough leftover to top off the resevoir as well.
Then the instructions said to start the engine w/ rad cap off, and let it get to operating temperature. I did that, and the rad burped twice (air bubbles escaping), and the rad fan came on a few times. But even then, I still didn't have to open the 2nd jug of premixed coolant in order to top off the radiator.
Any idea why I can only get in about 4L of coolant when the manual says it takes much more than that? Did I do something wrong? Or was there just extra coolant in the block that wouldn't make its way out of the system without removing some hoses, and that's what occupied the extra space?
Thanks.
