Is that the Pathfinder frame?
Though that was from the FJ Cruiser.
The bottom frame is a complete truck frame and its only the support beams for the box that are the cheesy framing on top. Have a look at the rear of the cab going to the rear of the truck axle on the bottom. Full truck proper frame where the springs are hooked up to. The other material should hold the box quite easiely as its not all that heavy on that model of truck at all. Actually not as bad as it looks.
And I thought the rust on my old 240sx was bad. Quote from: barrie1 on November 24, 2007, 01:26:49 amThe bottom frame is a complete truck frame and its only the support beams for the box that are the cheesy framing on top. Have a look at the rear of the cab going to the rear of the truck axle on the bottom. Full truck proper frame where the springs are hooked up to. The other material should hold the box quite easiely as its not all that heavy on that model of truck at all. Actually not as bad as it looks. Look again Barrie, the leaf springs are attached directly to the improvised frame.
I would have to see it closeup to be sure but it does look like it is going back a far ways on it. I suspect its frame work from a shelving kit which actually may have very strong I-beam type of strength. I wouldn't use it myself but some folks are not all that swift it appears.
