It was fairly warm here today so I washed the Miata and took it out for a nice drive. I didn't quite get to the redline but I did get close a couple of times...
. The oil will be changed this week and then it's nighty night for the winter
A preliminary list of mods/maintenance to do:
-new wheels and tires
-change out the springs
-remove the aftermarket alarm system
-remove the chrome style bar
-seek and destroy the vibration from the left side of the dash/instrument panel that occurs between 2700 and 3200 RPM
-replace transmission and differential gear oil (most likely to be done in the spring)
-replace timing belt, tensioner etc., water pump, front main seal, valve cover gasket(which is just starting to leak)
I'm probably forgetting something but that's the list so far.
