Author Topic: check fuel cap warning  (Read 3088 times)
Offline carburator
« on: October 03, 2007, 08:35:57 am »
I have a check fuel cap warning message on my dash. I have taken off and put back on the fuel cap and turned it tight lots more than just a few clicks. what is this ? TIA
Offline inco
  • Carma: +2/-19
Re: check fuel cap warning
« Reply #1 on: October 03, 2007, 08:42:34 am »
Time to trade in the car ::).  But if you have to keep it it sounds like a trip to the dealer is in your future to get a Hal Hookup and check out your operating system. Maybe the Ram roamed. ;D
Offline initial_D
  • Carma: +14/-0
« Reply #2 on: October 03, 2007, 08:52:51 am »
Doesn't like the gas you put in?  :) Per hap a power recycle of the electronics might help - disconnect & reconnect battery terminal. Else see dealer for further error instructions.
Offline Allen
  • Carma: +1/-0
  • Cars: 11 Escape, 09 Accord Coupe, 06 Xtrail
« Reply #3 on: October 03, 2007, 09:25:44 am »
I had that once, checked the cap tightness the light stayed on , went to the dealer they found nothing, they reset the warning light and it never came back..  Try what Initial said, if it comes back then go to the dealer..
  • Carma: +32/-31
« Reply #4 on: October 03, 2007, 09:37:07 am »
IIRC the light will not go off until the car has been turned off and on 3-4 times and the fault has not re-occurred.  Every time the engine is started the OBD checks fuel system integrity
Offline carburator
« Reply #5 on: October 03, 2007, 10:02:13 am »
I have been using regular octane from esso or shell or petro can for about the last two years. This warning has been on for about a week and comes on everytime even though the car has been parked and re-started. Will go the dealer and see what they say.....
« Reply #6 on: October 03, 2007, 11:54:56 pm »
Sounds like possibly the rubber seal on the cap could be tired and need to be replaced. the dealer will be able to read the code and tell you exactly what the problem really is. Hopefully it won't be very serious at all.  :)
Offline Trainman
  • Carma: +4/-1
  • Tree Whisperer
« Reply #7 on: October 04, 2007, 12:33:06 am »
My truck is prone to this if you overfill the tank, ie try to squeeze more in past the click off of the pump.  It does something to the computer as it messes up the evap system and sets the light off (in my truck it sets off the check engine light as there is no separate gas cap light).
Remedy?  Easy, I do not try to get in that extra 1/2 liter and just stop filling when the pump stops automatically.
But could also be a faulty cap.
Offline ovr50
  • Carma: +9/-120
« Reply #8 on: October 04, 2007, 12:40:44 am »
Just sounds like the emissions system warning due to a not-well-tightened cap at one time (even if corrected now). Usually involves a quick trip to dealer, and a reset (not a big issue, but still annoying). Worst car I had (in fact the only one that did it) was a '02 Impreza, I must have had 5 or 6 CELs for fuel cap (even if it was tight). Could also be a fualty sensor.
and
Offline carburator
« Reply #9 on: October 04, 2007, 01:10:52 pm »
Ya , I will give it a bit of time, like at least another fill up. It is true that sometimes I may have squeezed in a little extra. I know that this can cause serious problems if you over fill your gas tank and gas gets into that little hole at the top of your gas tank inlet that leads directly to the emmisions control system.Hopefully its just a faulty cap.
Offline dash
« Reply #10 on: October 04, 2007, 04:15:24 pm »
If it is a faulty cap, try not to buy one from Cdn Tire, the emission folks tell me they have a high failure rate when does caps on cars being tested
"Why be quiet, and thought a fool, when you can speak up and remove all doubt"
« Reply #11 on: October 04, 2007, 10:14:45 pm »
Dash has a good point as I would rather buy one from the dealer as they are not all that expensive anyways and know it will be the correct one for sure. I have also heard that about their gas caps as well.  :)
« Reply #12 on: October 04, 2007, 10:31:11 pm »
 ..i don't give a C(r)AP.................Constipado rules........... :-X :-X :-X
Offline carburator
« Reply #13 on: October 05, 2007, 07:59:28 am »
No I wouldn't buy a cap from crappy tire. At least thats what I was taught to call it as a kid.
Offline carburator
« Reply #14 on: October 09, 2007, 10:07:14 am »
warning light does not come on anymore. don't know what I did diffrently. Only thing I remember is that i filled the tank with more gas to the top for the weekend. (prob. about a quarter of the tank made it full).
Offline dr_spock
  • Carma: +10/-4
« Reply #15 on: October 09, 2007, 06:46:02 pm »
Probably you corrected the error condition a few clicks ago, the computer finally updates.   Or your car just realized it is a Honda and Hondas don't do that check light thing.  :)
