It's not random enough to completely cancel everything out. You'll have several "high spots" on the rotor, which will affect the degree of vibration you feel. For instance, one high spot will appear as a single vibration per revolution of the wheel, while ten high spots will feel like your wheel is falling off. Since you only feel it at high-speed stops, I wouldn't worry about it as long as the rotor has adequate thickness. Make sure it isn't some other cause such as a loose caliper, and wait until the rotor is used up or you start to feel vibrations during normal braking to replace it. You should replace your pads along with the rotor, as the old rotor will have grooves and you don't want the old pads wearing those same grooves into a brand new rotor. Replace pads and rotors in axle pairs as well, to keep the car from pulling to one side during braking.
