Hi guys, RE: 96 Honda Accord EX, 4 cyl. (not EX-R, VTEC) @ 320K
The car seems to be running hot, but only under specific circumstances. The temp reads in the normal range when on the road, but then shoots high after coming off the highway and entering city traffic.
In city traffic, the temp then varies from near normal to high, depending on whether the car is in motion (i.e. wind cooling effect?). Also, when idling at a light, the temp rises, but the fan does not turn on. However, when I turn off the ignition, the fan comes on straight away for a period of time.
Why would the fan remain off while at idle (with high temp) but then turn on after I turn off the ignition?
My mechanic suggests a new water pump and thermostat for $500. However, the water pump was changed with the timing belt at ~300K.
Thoughts? Thanks in advance...
