ok,, had the oil change done at the stealership. I told service advisor to use synthetic oil and I'll pay the difference from my freebie regular oil change.. He asked me if I was racing the car.. and I said "no i drive 90% city thats why Id like to use synthetic"..cut the story short,, he did not recommended it and he suggested to do frequent regular oil change than use synthetic.
Barrie had mentioned ""My one Fleetwood has this device option and syn does not register on it properly at all. Many of the other makes are the same
.. This is most probably the reason why he discouraged me in using syn..
anyway at 30,500Km.. They need to replace a faulty waterpump (leaking).. which I am surprised.. Tech also found a leaking transmission on right axle.. and of course they reaplced the belts that are wet due to leaky wpump...all done under warranty.. car is 2 years old..
I had a 92 mazda MPV with 230Km,, and only replaced the original pump bec i changed the timing belt.. . and here I have a car with 30,000KM with already major service done..
