Can I just get both springs installed or do I need to install the shock absorbers as well? I don’t think I want to install used springs on my car, because I just installed a used stablizerbar a few months ago when the old one broke and last summer I installed a used ac compressor, which broke down in the middle of the summer heat wave
Thanks for your help guys
Can I just get both springs installed or do I need to install the shock absorbers as wellIf the spring was truly broken then the strut insert (the shock) will be BLOWN.
I don’t think I want to install used springs on my car, because I just installed a used stablizerbar a few months ago when the old one brokeSo ... what's the problem, why buy new? on a car that has essentially no value.
last summer I installed a used ac compressor, which broke down in the middle of the summer heat wave So your comparing a used AC compressor with and used spring.
Used AC compressors are a very dubious buy.
If you want to throw away money then I'm happy for you. But the sensible thing on a 7 year old Alero is to buy a used strut from a wrecker. Research, but I believe Grand Ams have the same part. V6 or 4? There must be a zillion good ones available. When you get the strut it will have the spring inside it. I could install a complete strut in that car in 10 minutes. SO me thinks your mechanic is greedy.
