AFAIK in Ontario the center yellow lines are advisory (i.e. suggestions) just like all the yellow signs. There is nothing in the HTA stating that you are forbidden from crossing those lines. Now, if you pass someone on a double yellow then the police can charge you with failing to yield to oncoming traffic (assuming there is any) or dangerous driving, but there is no passing on a double yellow line offense.
Fuzzy, care to elucidate further?
You are more or less correct. Your possible charges are a little out of whack but you got your point across. Yellow lines are suggestions....And double yellows are even stronger suggestions. You'll generally find double yellows that correspond to this section of the HTA...
Driving to left of centre prohibited under certain conditions
149. (1) No vehicle shall be driven or operated to the left of the centre of a roadway designed for one or more lines of traffic in each direction,
(a) when approaching the crest of a grade or upon a curve in the roadway or within 30 metres of a bridge, viaduct or tunnel where the driver’s view is obstructed within that distance so as to create a potential hazard in the event another vehicle might approach from the opposite direction; or
(b) when approaching within 30 metres of a level railway crossing. R.S.O. 1990, c. H.8, s. 149 (1).
I'm done elucidating now...I feel much better.
